MetroMPG.com mailbag: is lowest RPM really best for max MPG with big displacement?
Got this question recently from a MetroMPG.com visitor:
I can say definitively that in all the vehicles I've driven with fuel economy instrumentation, the best cruising efficiency is achieved in top gear at the the lowest RPM. (Level road, constant speed, no other traffic creating aerodynamic effects.) That said, most of the vehicles I've driven have had small displacement 3 & 4-cyl motors. I've only tried a couple of V6's with instrumentation. I'm not saying it's not possible that much bigger 6- and 8-cyl motors may behave differently. I just don't have experience with them. The only way to know for sure is to get instrumentation and try it. |
Theoretically, but I recall a discussion that an engine has an ideal "piston speed" of 1350 ft/min (total travel) for the best Economy. I know in my 1.8L, constant load at 1500 RPM is less efficient than the 1800-1900 RPM, which is closer to the 1350 speed mark...
More testing/research may be required :turtle: RH77 Quote:
Piston speed? Have to say that's a new one to me.
--- Had a followup question from the Jeep guy: Quote:
Pre-OBD2 vehicles like yours can use a custom electronic gauge called the SuperMID. Check this thread for more information: [CRXMPG FAQ] SuperMID and 1990 Toyota Truck |
1 Attachment(s)
I remember my dad's Chrysler Intrepid having a flat MPG curve to it too.
Attachment 20 Originally posted April 24th, 2007: Quote:
A jeep is not very aero. I would think that penalty alone should kill the FE with speed. Plus with out instrumentation who knows what really going on. I have also heard this before but not from anyone who was using instrumentation.
Interesting. Hopefully some one will chime in who drive a car with excessive power. |
Hey, "The Jeep Guy" here, I just wanted to say that, I don't seem to see any difference between 55 and 60mph, I actually see a better miles per tank when I drive 60 rather than 55. My ZJ has a 23 gallon fuel tank, so I'm guessing that it's pretty accurate at fill-up because more gallons are used than smaller vehicles. I've taken my factory roof racks to try and improve the mpg, but I don't feel or see a difference at fill up. But one thing I do notice while driving is it's much easier to accelerate on a half full tank than a completely full one. I've also noticed that I've gotten a slight but noticeable increase in fuel economy after replacing my OEM Air filter to a K&N Filter.
I'm Also thinking back to the whole truck thing where a truck actually gets better highway mpg with the tailgate up than down because of the dome effect created within the tailgate. Theoretically this would create drag, but in a wind tunnel it in fact creates the opposite. With a large displacement engine, there's also usually a large car. I think that if your going at 60mph, the weight of the vehicle causes the momentum to continue on longer and, since momentum has built up at this higher speed it's easier on the engine cause the weight is pulling the car forward and helping out the engine. I've been in V8 Cadillac's with Instant fuel economy, and when I watch it, it seems that when as the car accelerates to a faster speed, the fuel economy goes up when they put on the gas. I'm guessing that from the large displacement, lets say 4.7L, at idle speed of like 15 mph there is still alot of extra fuel being injected into the engine and fuel is wasted, but with a little bit on the gas you go faster and there isn't much more fuel being injected cause it doesn't take much more RPM to get it from 0-60. I never have to go over 2000 RPM to go anywhere, and My Jeep shifts at 1500 if I accelerate lightly. I can easily get from 0 to sixty hitting the gas barely at all. If I wait long enough The Jeep can Idle at 20mph. This could be why that Intrepid had a flat mpg curve at speeds over 60, it was a heavier car, and once you get a heavy car going, it goes, and the car doesn't have to do much more to go from 60 or from 70mph. I love coasting in my Jeep, cause it coasts for miles and my rpm's are near idle. Also, with the SuperMid, Where do I buy one and can I get it in US Customary? |
ah, yea, but it did somehow lower my rpm's a bit after moving to a K&N, why is this?
What are some other things that can improve the MPG of my Jeep, Not including removing unnecessary weight. |
I always drive economically, especially when no one is looking. I can't really drop any weight, I could dump the spare, but you never know with the Jeep (the side of the road seems to be more interesting than the road itself!) I've got the tires about 1.5psi overinflated and removed the roof racks. I was wondering about making a home-made intake from pvc and the cold air intake filter with some heat deflectors to try and make it breath a little better. How much difference in mpg is a clean Jeep vs a Muddy one?
This varies widely among vehicle manufacturers, but you may want to actually warming-up the incoming air.
I'm not sure about Jeeps or Chrysler brands, but Saturns and some Hondas respond to this. Same for cold starts -- intake air temp is generally one of the feedback parameters for the FI system. Generally, warmer = more efficient. As far as mud, it depends on how thick the coating is :thumbup: RH77 Quote:
