Old 07-16-2009, 01:41 AM   #11 (permalink)
Grasshopper
alohaspirit's Avatar
Windjammer - '96 Tracker
90 day: 27.02 mpg (US)
Budget "Insight" - '91 CRX
90 day: 50.96 mpg (US)
of course the rain doesnt matter when you guys remove your alternators
Past Present Future?
Old 07-16-2009, 01:53 AM   #12 (permalink)
Well there is good reason to keep the underhood stuff dry. Rain falling on hot parts could cause uneven cooling and break seals etc. I've read enough threads on various forums about people washing their engines and causing huge problems to want to keep mine dry
Old 07-17-2009, 06:12 PM   #13 (permalink)
micondie's Avatar
moby van - '03 Caravan SE
90 day: 19.74 mpg (US)
Those vents look good and are placed in the right position for venting the radiator. I am wondering if you are getting warm air into the air intake at the base of your windshield.
Old 07-18-2009, 02:32 PM   #14 (permalink)
vents
Originally Posted by SVOboy View Post
How did you add the vents? I am not sure how useful they are, can someone else chime in on the theory and its soundness here?
The theory is good and goes back at least to Kamm,who's "Kammback" would be useless without the attached flow the pre-windshield engine bay outlets helped generate.The P-51 Mustang was designed with particular care to the cooling system for drag reasons.Walter Korff advocated their inclusion in passenger cars in the early 1960s.Dr.Morelli used Pininfarina's windtunnel to perfect the "vents" of the CNR "banana-car" and was able to match the velocity of flow of the escaping air to that of the surrounding flow field.-------------- Without a windtunnel I would have no idea how anyone might pull this off.----------------- My opinion is that the area near the A-pillars,where the air is accelerating around to the side of the car,would be the location of lowest pressure and best scavenging.Also,if a coolant hose blows,you don't hose down the windshield with glycol,and you've got a chance to see your way to the shoulder of the road without a crash.
aerodynamics, miata
New here... doing a bit of hypermiling in my Miata. awarenessideas Introductions 1 01-08-2009 06:42 PM
LA Auto Show: Mazda Miata SVOboy EcoModding Central 4 11-21-2008 05:02 PM
What's the worst that could happen?? and other modding ?s I have swoody EcoModding Central 25 09-17-2008 08:23 AM
Mission Impossible: Taming the Giants (Excursion/Hummer modding) Big Dave EcoModding Central 67 04-06-2008 09:20 AM
New user intro and pick-up aero modding Blackbird Aerodynamics 4 01-28-2008 01:06 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
