Old 10-09-2008, 09:45 AM   #11 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
a few 80's and early 90's cars wich had quite good to exeptionally good Cd's used these cut off rear arches... unfortunately big wheel arches again became a fashionable in the late 90's and this smart feature disapeared.
here's a few examples of car wich more or less cut off rear arches... most have pretty great aero for their age
1986 opel omega 0.28 Cd (one of my favourites)
1984 opel kadett (later rebadged daewoo nexia and pontiac lemans) 0.32 Cd
1983 citroen bx 0.34 Cd
1986 citroen ax 0.31 Cd
1996 Smile (greenpeace converted renault twingo) 0.25 Cd (compared 0.35 for the original twingo)
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 10-09-2008, 02:33 PM   #12 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
Wow! Those are some neat pics! I'll bet that any blockage at all helps
keep the air flowing the down the side of the car smoother..
The massive hole above my wheels is exposed to the side air rushing by..
If it was high pressure air or low pressure air, it seems that either would
disrupt the air flowing down the side of the car.
I think just about anything would help this situation. But the scangauge is the final judge.
Cheers,
Rich
Old 10-11-2008, 08:31 PM   #13 (permalink)
New tape and coroplas added
The back skirts are close to the tires, but are doing okay. But the front ones are getting worn down in the middle a little when I do turns in parking lots.
I'm gonna have to trim a little arc in the middle of them and they are
going to be really ugly.. (Or, maybe my wife won't notice)..
Cheers,
Rich
Old 10-11-2008, 08:57 PM   #14 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Taurus GL (Sedan)
90 day: 18.61 mpg (US)
Those miniskirts look really good... I think you should definitely try using a metal brace and making a full rear skirt. The way the gray trim is shaped, your car definitely has the potential for it.
Sorry to be off-topic, but do you have aftermarket headlights or something? They just don't look right for some reason...
Old 10-11-2008, 11:29 PM   #15 (permalink)
I was looking for a zero drag profile, so I went with flat, instead of having the budge sticking out. It seems like I've got 50 to 60 percent of a Full skirt, so I'll try this for a while and see what happens.
The headlights are standard OEM. Here's a different angle.
Haha.. They still look a little weird..
Cheers,
Rich
Old 10-12-2008, 12:39 PM   #16 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I like it! It's not ideal, of course, but it's better than nothing and looks pretty neat, especially with the rim treatment,
Old 10-12-2008, 03:40 PM   #17 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 scenic
90 day: 43.09 mpg (US)
megane - '97 megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Prius
90 day: 55.12 mpg (US)
Thanks for this picture, I never saw this twingo.
Here are 2 links I just found with info and pictures :
The engine is a 358 ccm and weights 35kg !!! It consumes 3.3 L/100 km (71mpg) instead of 6.7 L/100 (35mpg).
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 10-13-2008, 12:20 AM   #18 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
Xringer,
looking good
and I would not worry about increasing drag by catching airflow with the mini skirts
judging by Lunar's post you are in good company
but to crexcrex point I bring my own failed test data of full skirts
I did a quick test with scan gauge at 65 mph the cover shown below
they were at best no improvement & I do believe, as crexcrex said
trap the turbulence and cause more drag.
but...
I have open wheel wells in front of and behind my rear tires
(my truck bed is sort of hollow looking in that area)
I believe I was catching air from under the vehicle & not letting it equalize thru the wheel opening
you appear to have closed wheel wells - front and back
I predict you will be gaining on this mod
measuring it might be an issue if you don't have instrumentation
Hope this helps
waiting to see your results
might mod my card board wonder skirts to match
Concrete
Start where you are - Use what you have - Do what you can.
Old 10-13-2008, 12:31 AM   #19 (permalink)
Originally Posted by crexcrex View Post
One can easily note that there is a roof rack in place not to mention the extra weight, i would think that eliminating the drag from the turret might be an idea.
The rear spare, how many pounds are there bieng given a free ride plus the wind turbulence the spare causes.
Mods may well be fine and dandy but i do think that the obvious is bieng overlooked............
I am only expressing a opinion that you may well dismiss as bieng trivial, mods are great as long as one does not overlook the obvious
I did some yarn testing the other day. I taped three 6 inch pieces of yarn
on top of the spare so I could see them fly around as I zoomed up US95..
Didn't happen.. The three yarns just lay there like they were asleep.
Maybe my Coroplas Spoiler and Wake Boards are blocking the spare.?.
I moved the yarns to my rear window. I'm starting to think that's going
to be a low turbulence area too.
Cheers,
Rich
Old 10-13-2008, 12:35 AM   #20 (permalink)
GreenMile - '00 Protege ES
90 day: 34.45 mpg (US)
I think even partial skirts would be an improvement, contrary to what crexcrex believes. The logic he uses states that air gets trapped up there with no escape and thus must create drag, so presumebly a full skirt would be even worse by this logic.
The partial skirts certainly must improve laminar airflow some and I think it is a good compromise for those that do not feel a full skirt is practical.
http://benw385.vox.com/
'Blog' on the open source electric motorcycle project.
Please come visit and comment!
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/micro-mini-wheel-skirts-5438.html
Posted By For Type Date
citroen ax 1995, citroen ax 11 | Picsicio This thread Refback 10-11-2010 02:32 AM
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 34 01-07-2012 12:40 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 08:45 AM
I got accosted for wheel skirts! lovemysan EcoModding Central 33 10-12-2008 08:12 AM
Wheel skirts for the aerodynamically minded Daox Aerodynamics 14 01-28-2008 12:23 AM
Found a coastdown hill! Mini comparo: windows vs skirts vs hatchback MetroMPG Aerodynamics 4 11-28-2007 12:40 AM
