Old 10-06-2008, 11:23 PM   #101 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Hey Yoshi, what do you think about a mass flow sensor in a liquid? too heat conductive?
Old 10-06-2008, 11:34 PM   #102 (permalink)
dcb
needs more cowbell
dcb's Avatar
hmm... well there are thermistor liquid flowmeters for things like blood flow in an artery:
Digital temperature compensation of a thermistor flowmeter
Old 10-07-2008, 02:36 AM   #103 (permalink)
dcb
needs more cowbell
dcb's Avatar
Here is an interesting read for possibly a solid state solution:
http://www.sskteracon.com/ExternalFiles/AN685.pdf
Old 10-09-2008, 03:28 PM   #104 (permalink)
Suzi - '94 Swift GA
90 day: 48.94 mpg (US)
Prius II - '05 Prius Package 6
90 day: 46.51 mpg (US)
flow meter
When I was in college we used a flow meter like this for a lab once.
The fluid pushes up on a ball that is more dense than the fluid you are working with. You can calibrate it to take eye readings (with a glass tube), or use some sort of dual or triple coil system to determine the location of the (usually ferrous) ball by determining magnetic field in the coils. It may sound hard, but I remember it being pretty easy. We were getting fantastic results with water, but it should work for gasoline as long as your materials can withstand the environment.
EDIT:
These are called rotameters or area meters. I haven't found any that will just give a quote that have a reasonable cost, but most are made from stainless and glass. I did find one that was about right, but I guarantee it is way to expensive. It has low flow readings (one model as low as 0.02 gph; my 1.3L idles at ~0.2 gph). They also have ouptuts from 4 to 20 mA, which should make them usable without modification. ROTAMETERS with electric output. DATA SHEET.
Old 10-09-2008, 04:14 PM   #105 (permalink)
"Inconceivable"
moorecomp's Avatar
My ZX2 - '99 Escort ZX2
Team ZX2
90 day: 39.53 mpg (US)
Her RAV4 - '011 Rav4 4x4
90 day: 23.7 mpg (US)
Hey guys,
How about measuring the differential pressure across a restriction in the fuel line. No flow means equal pressure across the restriction, the higher the flow the greater the differential.
Low Cost Wet/Wet Differential Pressure Sensor
moorecomp
Mancelona, MI
Old 10-10-2008, 01:37 PM   #106 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Good find. I think it could work well with the mpguino. One would have to change some of the programming. Or just build a circuit to make the sensor run a 555 timer chip to create pulses for the mpguino to read, pulses that are variable based on the input voltage that varies with pressure.
Winter daily driver, parked most days right now
Summer daily driver
Old 10-10-2008, 02:04 PM   #107 (permalink)
"Inconceivable"
moorecomp's Avatar
Team ZX2
Wagonman,
One thing to consider, the fuel pressure would have to be a constant pressure, regardless of the flow. A fuel pressure regulator, if not already installed, looks like it could be had for $20 or so.
moorecomp
Mancelona, MI
Old 01-06-2009, 10:40 AM   #108 (permalink)
Mr. Jones - '02 Fabia Classic
90 day: 19.09 mpg (US)
Send a message via MSN to Cepheuz Send a message via Skype™ to Cepheuz
i just though of an idea, simple one, but let me know
lets take the fact that my engine is 1289cc (witch would be at WOT)
then the fact that the fuel mix is 13.7:1
that would make the fuel amount @ WOT 94.08cc
and there is only one fuel enrichment and thats the load
so add a volume (the ones in stereos and guitars)dial with a resistor for 6 volt 6volts = 94.08cc
tap into the throttle cable or the throttle to move the volume dial (i'm sorry, i realy don't know the name of it) and ad a contact point the the load enrichment device and do a map for voltage / cc
6volts=94.08cc 3volts=47.04, etc..
add a relay with a resistor and a capasitor to the mix and you can get higher pulse for more acceleration and a pulse for mix increase
could this work?, i might try to do a scematic
Old 01-06-2009, 11:17 AM   #109 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
Cepheuz, i don't follow your logic entirely but i think you may have just invented what is called a throttle position sensor or TPS.
Old 03-12-2009, 12:37 AM   #110 (permalink)
ok so this is another, i had a 86' VW Golf GL, it had the k=jetronic fuel system, it had injectors fed by tubes to a control system that meter the ammount of fue depending on the volume of air, in this system there was a fuel pump that whe called cricket bacuse of it sound, its job was to maintain the presure the low presure injectors needed to work, once it reached this presure it shut off automaticalty
so why not natch one of this, connect it between the fuel line and the carburetor and measure the pulses of electricity when it turns on (it turns off automatiacly when it reaches a presure of 3psi i thing or something like that) and its small one just has to figure out the electrical side that sences current flow and sends a pulse, or just put a diode led and it will turn on every time there is flow and conect that led to the light thing i read about in the begining of the thread (the one with the two holes and the ball)
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 11:35 AM
In a world where Jeeps get horrible gas mileage.... EcoJeeper Introductions 16 03-26-2009 01:09 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 09:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
