Old 04-13-2009, 06:27 PM   #131 (permalink)
68.9 mpg best trip
Mercedes 89 D - '89 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Octavia TDI PD
90 day: 42.04 mpg (US)
Send a message via Skype™ to oldbeaver
Fine, tks a lot. Very ingenious!
I will study it now.
Old 04-14-2009, 12:19 PM   #132 (permalink)
68.9 mpg best trip
Thumbs up Using just throttle position and rpm and speed
That is interesting. Need to research the function: mpg = f(RPM, Thr, Speed)
Makes a lot of sense to me.
Question: how do you plan to translate it to reasonable results (even relative results serve as for testing modifications), and calibrate it?
Good idea. Nice if you share your progress on this.
Originally Posted by dcb View Post
I do have something that is pretty cheap in mind for the mechanical diesels, but you have to install a throttle position sensor and a rpm or pump rotation sensor and a speed sensor, and I or someone has to teach the guino how to make sense of it.
I'm also thinking about just using a function like speed/(throttle position*rpm) for my bike too, to see if it is reasonably accurate.
Old 04-14-2009, 12:36 PM   #133 (permalink)
68.9 mpg best trip
Using Bernouilli principle for metering flow
Hi James, you know about thermodynamics. Have you ever make such a flow sensor? It may be interesting if you do. Would it be accurate and cheap?
We need two for diesel fuel flow metering. Keep us informed of your experiments on that.
Originally Posted by JamesLaugesen View Post
Hi everyone, my first post here, I've read through this thread with great interest, some real cool experiments happening.
Thought I'd propose some non-mechanical ideas for measuring flow:
A venturi meter.
Along the lines of this:
Venturi Flowmeter
Of course with something clever to observe the pressure differential as a signal.
Inertial meter, or coriolis, whatever you want to call it.
Best description I can find is good 'ol wikipedia:
Mass flow meter - Wikipedia, the free encyclopedia
Need some imagination to use it in a vehicle, especially a bike, but at least the engine could provide a good consistent vibration.
Old 04-14-2009, 12:49 PM   #134 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
LOL, what progress? I need a rabbit
Old 04-14-2009, 12:56 PM   #135 (permalink)
68.9 mpg best trip
Thumbs up Only one flow meter?
Wagonman,
Interesting. Can you explain how you need only one flowmeter if you install a pressure regulator?
Besides diminishing error, you cut cost to half, on flow sensors.
I listen. Try to make a diagram if necessary....
Tks.
Another: What is positive displacement pump?
Originally Posted by wagonman76 View Post
Another problem with the ball type is it needs to be held steady and vertical. Won't happen in a car. I agree with the positive displacement type.
I am not familiar much with diesels. But with most cars, you could install a separate pressure regulator and abandon the original. Then you could install the flowmeter between the regulator and engine, hence requiring only one flowmeter and halving your margin of error.
Old 04-14-2009, 01:11 PM   #136 (permalink)
68.9 mpg best trip
A cheaper approach?
Diesel John,
I overlooked this comment. You wrote:
"For a diesels that return to the tank, I would think that a TPS on the fuel regulating shaft, a tach pickup on the injection pump, and dcb's computer would be an easier path, and a less expensive path to follow than what I did."
I have a Throttle position sensor for my Nissan RD28 engine. Have a tach signal of it as well, which I converted to drive my tachometer.
What is DCB´s computer? What about the speed ?
Have any further ideas on this approach?
Thank you for sharing.
Originally Posted by diesel_john View Post
What I have on my diesel rabbit now is an old Zemco mileage computer. The Zemco flow meter has been restored with a 6mm plastic BB and a red LED light source. And because the diesel sends more fuel back to the tank than it uses, i have fuel diagram similar to post 61 bottom diagram. Also see post 84 and 73.
Old 04-14-2009, 01:45 PM   #137 (permalink)
dcb
needs more cowbell
dcb's Avatar
Have a look here for the operation (and possibly follow up discussion as this is diesel related and not carbureted). Diesel instrumentation
The control sleeve position is what determines the volume of a stroke. If the control sleeve position can be determined by rpm and throttle position, then cool. Still a little fuzzy on the linkage inside the pump.
The computer is the mpguino I'm sure. OpenGauge / MPGuino FE computer - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
You might have to roll your sleeves up to get the answers you seek.
Old 04-14-2009, 05:40 PM   #138 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
On my rabbit I use the zemco recirculating ball flow meter just because I already had it and the old Zemco computer. Although one needs to be careful not to get the fuel temperature to high when not circulating back to the tank. A fuel cooler would be applicable, but it also increases the volume of that fuel loop which makes the flow meter less responsive to transient inputs.
Old 04-14-2009, 06:03 PM   #139 (permalink)
dcb
needs more cowbell
dcb's Avatar
Hey John, you may have mentioned this already, but it might be simpler to figure out/calibrate diesel consumption if you measure the return line flow, and subtract that from what the flow "should" be in the main line if the control sleeve were at max travel for that rpm. idle consumption detection might not be an issue anymore and fluerburger might actually be a good fit (what is min return flow rate?).
Old 04-14-2009, 07:03 PM   #140 (permalink)
MP$
We touched on that idea before but not from that angle, the return fuel is substantial. Your thinking perhaps that the return fuel is the inverse of comsumption. hmm... lets look in that pump again. l like your diagram in post 137 better. better view of vane pump pressure regulator
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 11:35 AM
In a world where Jeeps get horrible gas mileage.... EcoJeeper Introductions 16 03-26-2009 01:09 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 09:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
