Old 04-06-2008, 10:19 PM   #11 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
Cause if you don't have a scan gauge, you'll never have accurate fill ups... cause you'll never know how much fuel you used and how much to put back in to get accurate fill-ups..
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 04-06-2008, 11:12 PM   #12 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
how does a scanguage give you accurate fuel used data? does it know the size of your fuel tank, your injector pulse rates, voltage to the pump, regulator settings?
I dont see how it could be any more accurate than anything else..
Old 04-06-2008, 11:39 PM   #13 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Tank: Yes - you tell it
Injector Duty Cycle: Yes
Pump Voltage: Implicitly (but this doesn't matter so much)
Regulator Settings: Implicitly
It knows no more than the on board engine management does
It's also calibrated by the meat person operator @ fuel up. The more you use - the more accurate it gets
Mine has been spot on for quite a few fill ups now LinearLogic did an awesome job programming the thing
Challenge me, or correct me, but don't ask me to die quietly.
Old 04-07-2008, 12:46 AM   #14 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Chris -
I agree, so I don't use the SG for reporting my MPG. I use the GPS adjusted odometer and multiple tank fill-ups for my fuel log. The SG has a "cheat bias" that you use to calibrate fill-ups. If you change the way you drive between fill-ups, or you're driving context changes, there is the possibility that the cheat bias would lose validity between fill-ups.
The SG requires that you input the size of the engine in liters, a speed adjustment based on non-OEM tire size changes, and the tank size.
From what I can tell, the SG does not know about injector pulses, 02 sensors, or fuel trim. If it did, I would expect it to report that data in the instant gauges, but it doesn't.
I only trust long term MPG, so I look at my MPG over 90 day fill-ups. The problem with my methodology is that is is harder for me to claim improvement of mods that have small effects on MPG.
I think the SG is a fantastic *relative* MPG barometer. With all else being equal, it can tell you that you are increasing or decreasing MPG consumption.
CarloSW2
American Solar Energy Society
Old 04-07-2008, 08:52 AM   #15 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Why was my post edited/altered without my knowledge? (title)
To make the subject matter of the thread a bit more self-explanatory. I do this sometimes - adding a few words on to a title in brackets.
Old 10-21-2008, 02:16 PM   #16 (permalink)
Red Egg - '95 Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
When i dont fill to the click, I'll do exactly what svoboy does on his log. On my next fill i add both of them, even if the fuel quantity bought is higher than the capacity of the tank. The distance traveled is still constant.
Old 10-21-2008, 07:59 PM   #17 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
If you under fill a tank, your FE goes up, but the FE on the next tank will go go down by the same amount.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Scanguage users - accuracy question Formula413 Instrumentation 7 08-26-2008 04:55 PM
