Old 05-15-2011, 11:56 AM   #21 (permalink)
The width of the Exhaust cutout lended itself to placing a strake on either side to channel airflow, the others are equidistant apart for asthetics.
The strakes probably do several things, but one of the most obvious is that they prevent low-speed, high-pressure air getting in along the sides of the car/tires from disturbing the flow in the central area of the diffuser.
Originally Posted by tugboat View Post
What guided you on how many strakes and where to put them (or spacing them, or something )
Looks very factory, I agree. Well done!
Old 05-18-2011, 05:02 PM   #22 (permalink)
I've Been AeroHauled
this looks professional. How'd you make the strakes. They don't look like coroplast???
Old 05-18-2011, 05:06 PM   #23 (permalink)
...they are coroplast pieces folded in half so bottom edge is perfectly flat...which also made them much more rigid.
Great tips for working with coroplast
The Following User Says Thank You to curv872 For This Useful Post:
BeatUpRanger (11-21-2011)
Old 05-18-2011, 05:08 PM   #24 (permalink)
Close up detail of the strakes
The Following 2 Users Say Thank You to curv872 For This Useful Post:
Fat Charlie (05-19-2011), jedi_sol (05-19-2011)
Old 05-18-2011, 05:10 PM   #25 (permalink)
And from the side
Old 05-18-2011, 05:22 PM   #26 (permalink)
Dr. Jekyl - '09 Mini John Cooper Works
90 day: 47.07 mpg (US)
Really appreciate your posting the pictures. That makes it clear as glass how to whip one of these up. I'm going to make one for my 09 Mini.
Old 05-19-2011, 07:37 AM   #27 (permalink)
How are the vertical strake attach to the coroplast. Just glue. Isn't the coroplast too flexible? Does it buffet around?
Old 05-19-2011, 07:48 AM   #28 (permalink)
Thanks so much for the coroplast tips!!
Old 05-19-2011, 10:05 AM   #29 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Are you planning any treatments to the rear inner fender area? There's a glaring hole in the last pic. lol
Old 05-19-2011, 11:11 AM   #30 (permalink)
The thought had crossed my mind, but it's not really necessary. The inner fender hole allows adequate ventilation for the rear exhaust and rear brakes. The strakes prevent most of the turbulent air from disrupting the flow of clean air through the diffuser.
2004 MINI Cooper S - Improving Aerodynamics iplaysdrums Aerodynamics 90 08-08-2012 02:13 AM
Drag Racing Aero Help Bennett_Racing Aerodynamics 33 06-28-2010 06:02 AM
rear diffuser fabrio. Aerodynamics 30 05-17-2010 12:36 AM
rear diffuser build thread LeanBurninating Aerodynamics 24 06-06-2009 08:32 PM
