Old 09-24-2015, 04:16 PM   #21 (permalink)
...beats walking...
TIP -- on 'thin' metal, use very SLOW motor speed, very light PRESSURE, and run the drill in REVERSE! That way, you're not gouging metal out with the 'teeth' but rather 'wearing' it away with the back-slant of the teeth.
The Following 2 Users Say Thank You to gone-ot For This Useful Post:
apc (09-24-2015), MobilOne (05-15-2016)
Old 09-24-2015, 05:19 PM   #22 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
We're already on winter fuel in our corridor. I wonder if you are too. Possibly much more potetial if you were to use E0 summer fuel. My mileage has already dropped 10% from my all time high a month ago.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 09-24-2015, 07:11 PM   #23 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Kill Switch
You can also try the cutting the signal from the Crankshaft Position Sensor.
It does not throw any codes on my 2013 Subaru WRX Sti.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following User Says Thank You to jedi_sol For This Useful Post:
apc (09-24-2015)
Old 09-24-2015, 07:42 PM   #24 (permalink)
apc
Mazda - '11 Mazda Mazda2 Touring
90 day: 38.93 mpg (US)
Indeed I came across that in your thread! That's weird tho as I've seen a CPS throw a code on an older Nissan. I'll be back at it this weekend.
Old 09-24-2015, 10:44 PM   #25 (permalink)
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
Step drill
Originally Posted by apc View Post
Ah but the problem is I need at least a 1" opening to reach the stem. I see cheap ones for smaller holes but 1" all hits $50. I could do a smaller hole with an extension but I want to use a hole plug to make it nice and pretty.
I just remembered I have a sheet metal nibbler at work. That's what I'll do - use the largest punch I have and just nibble the rest out!
Hmmmmmm I found one on Amazon for $10. Hmmmmmmm.
Harbor Freight has the large step drill for a reasonable price, sure comes in handy.
The Following User Says Thank You to iveyjh For This Useful Post:
apc (09-25-2015)
Old 09-25-2015, 08:15 AM   #26 (permalink)
apc
Ah, $20 is a little more tolerable! Maybe I'll just have to find more reasons to drill holes in things.
Old 09-26-2015, 04:58 PM   #27 (permalink)
apc
Pizza Pizza
Prototyping the wheel covers today.
Worked out the zip tie locations on the narrowest part of the spokes.
Punched out the holes with a screw driver. Doing this instead of drilling curves the edges inward so there's nothing sharp to rub on the tie.
Immediately I discovered that the ties have to be very tight else the cover will rattle. They also do move around a bit resulting in a slightly noticeable imbalance going down the highway. I'm going to drill the hole for the valve access and then prime and plasti-dip them. My hope is that the traction from the rubber will hold them in place so they not only don't slide but don't have to be zip tied so strongly. If they still move around I'll try adding a peg to the cover that extends down into the opening for the wheel center cap.
On a 10 mi or so jog down the highway I was bouncing around 56 mpg by the time I got off. Not sure how much I trust that tho. I filled up the tank today and came in at 38.6. Lower than my last fill. Doesn't make sense as I've been doing plenty of P&G and coasting in neutral, cruising in 5th unless I need some power. And the last fill at 39 mpg was only half hypermiling. Maybe I should stop buying Costco gas.
Old 09-26-2015, 06:07 PM   #28 (permalink)
Tinkerer
kafer65's Avatar
Team Mazda
I get that as well using the 50 pound zip ties. I used a heavy gauge zip tie early on and I could get those tighter and had less problems with slippage. I just inspect them and readjust them if I feel a wobble. Looks real nice mounted. I managed to mount my skirts today and all went very well.
Old 09-26-2015, 11:10 PM   #29 (permalink)
apc
Picked up the step bit from Harbor Freight. It does the job.
Put the hole as close to the slope as I could. Works out so it's not impossible to get at the valve. Technically. A little extension will make things much more practical when servicing.
Washed and primed.
The Following User Says Thank You to apc For This Useful Post:
BabyDiesel (09-27-2015)
Old 09-27-2015, 01:17 PM   #30 (permalink)
apc
Plasti-dipped.
