Old 03-20-2009, 06:02 PM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
misc signal sources.
I'm not even sure what vehicle this is exactly, maybe some kind of hyundai, but they put a vehicle speed signal on the obd port pin 14? Maybe this is your car if you have connections on 1,4,7,8,12,14,15,16?
Old 07-14-2009, 12:17 PM   #2 (permalink)
gyb
My car is a Hyundai Accent 2000 1.5L (Imported from Singapore) and it has Vehicle Speed in pin 14 of OBD2 connector.
4 - Chassis ground
5 - Signal ground
7 - K line
12 - Airbag
14 - VSS
16 - Battery voltage
It uses ISO9141-2.
MPGuino for Audi rmccomiskie OpenGauge / MPGuino FE computer 40 05-22-2011 10:18 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 03:09 PM
VSS, tach, injector signal logic wikityler Instrumentation 2 07-21-2008 12:02 AM
Signal Generator dcb OpenGauge / MPGuino FE computer 26 06-27-2008 11:29 PM
Opengauge/MPGuino development: Freeduino signal processing dcb OpenGauge / MPGuino FE computer 6 04-16-2008 10:40 AM
