Originally Posted by sparksnsaaben
At speeds below 50 to 60 mph, I can barely notice it behind me
Then stick to those speeds.
Surely it'll take longer, but it'll save a bunch of gas.
What minimum height should I build my aerodynamic "nose"? What is the best shape, one plane, three planes, etc.?
A bulge above the trunk height will do.
See
On Aerodynamics Pull Trailers as an exemple.
An approximation of a bulge with angled plates will work, just not as well.
I am also considering adding a "boat tail" if that would result in a significant fuel savings.
Boattailing the trailer would give a considerable reduction in drag.
Even simple angled plates will work.
Almost anything is better than a square shaped back.
Just don't add a round or circular tail fairing.
As of right now I believe that fixing the front aerodynamic disparity is the only thing required to meet the law of diminishing returns.
Changes to the front have smaller effects on the drag than curing the rear end.
Rounding off the trailer's front corners will help.
A spoiler on the car roof might help, but the gap is pretty large.
A nosecone on the upper part of the trailer (anything above trunk height) will likely work better.
A vertical splitter plate on the tongue can help to prevent crossflow.
Putting angled deflectors in front of the trailer tyres, and boattails aft of them will also help.
