Old 04-13-2010, 11:27 PM   #1 (permalink)
greyback - '95 Firebird Formula
Misplaced Wiring
I have my MPGuino but misplaced the wiring that comes with it.
What sort of wires do I need and what sort of connectors/plugs do I need?
Thanks so much.
Old 04-14-2010, 06:41 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
The quick fix is to open up a desktop computer and cut off a spare 3.5" floppy power connector and use that, i.e.
MPGuino Hookup (WIP)
The Following User Says Thank You to dcb For This Useful Post:
livewire516 (04-15-2010)
Old 04-14-2010, 10:18 PM   #3 (permalink)
and what should the person do who happens to be without a desktop computer? i was wondering along the lines of part no. from a radioshack or something.
Old 04-14-2010, 10:49 PM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
That I don't know. I have quite a few free desktops here (school had a pile for recycling, find them on curbs, family/friends etc) so it never occurred to me that they would be hard to locate. I havent seen anything at ratshack that looked like a good fit, you could just solder wires to it also.
can get one from the orient for $1.68 too
4Pin IDE ATA Power Supply Molex to Floppy Adapter Cable - eBay (item 260568448049 end time May-12-10 19:17:36 PDT)
Old 04-14-2010, 11:33 PM   #5 (permalink)
cut up some paper clips?
Old 04-15-2010, 09:08 AM   #6 (permalink)
I took a second look at what I needed to solder and laughed, it should be no problem. Thanks.
Old 04-15-2010, 09:19 AM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
cool, can I suggest soldering to the part that goes into the pcb by the bend in the pins? so you can easily add a plug later if one materializes? (bunch 'o solder on the plug part of the pins might not work so well later)
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 52 05-18-2012 12:52 PM
Big project-F250 pulling 20x8.5 enclosed trailer 5.0 Junkie Aerodynamics 70 04-11-2010 01:10 PM
rant -why is my wiring soooo hard work? modmonster OpenGauge / MPGuino FE computer 5 01-27-2009 07:13 PM
Fancy kill switch wiring extragoode EcoModding Central 2 10-15-2008 01:14 AM
DIY - Wire Tuck SVOboy DIY / How-to 4 01-25-2008 02:14 AM
