Old 11-25-2009, 06:17 AM   #21 (permalink)
Originally Posted by Christ View Post
The 1985+ 617's made ~120HP w/ the turbo from the OEM spec. They could be turned up and the wastegates locked to make up to ~150 or so
oops, 148HP was the L6 with aluminum head that came in the 86 300SDL
the turbo in the OM617 was too small. at high, sustained rpms it works like a blow drier and without intercooler your mpg will suffer.
the earlier (70s) burbs came with the 350 IDI which GM put in their vans as well. years later in the newer model they fitted them with the 6.5 IDI, they might have also used the 6.2 but i am not sure. yes pseudodiesels can be terrible as in the case of the 350, but quite good too as in the IDI VWs.
Old 11-25-2009, 10:13 PM   #22 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
I have owned a pair of 6.2 diesel suburbans, no real complaints save the crappy 700r4 transmission. The 6.2 was not a pseudodiesel and the 350dx was not really one either. The main issue with the 350dx was a lack of a fuel water separator and water sensor; any water and you blew the injection pump and heads. My father owned a 79 350dx diesel and once the goodwrench went in the thing went forever, the guy who bought it from him in 91 still has it on the road, go figure.
A suburban can hit around 30mpg on the highway with a 6.2 and a 5sp manual but high 20's are more common in that combo. My 700r4 6.2 delivered 26mpg until it crapped out.
The main weakness of the 6.2 is that it has a cast iron crank and that is where most of the failures come, if GM would have pulled its head out of its arse during the 5.7 fiasco they would have realized that saving $25 to cheap out on something critical wasn't worthwhile.
Ah well.
Old 11-26-2009, 12:57 AM   #23 (permalink)
yes i have talked to someone that was getting close to 30mpg.
i have found that if an injector has been placed where normally
a sparkplug woulda been it is either a pseudo-diesel or was strongly
inspired by a gasser. purpose designed diesels place the injectors
near the top of the cylinder head or with the nozzle injecting nearly
perpendicular to the piston.
Old 11-26-2009, 11:06 PM   #24 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Perpendicular to the travel of the piston, or to the piston's head? (I think you mean directly above the piston, as in a Hemi-type gasser.)
I'm still thinking about replacing spark plugs with injectors and making a Ford 300 inline 6 into a medium output TD. It's a completely iron engine, so I think it should hold up with better pistons and higher compression.
Old 03-24-2010, 10:10 PM   #25 (permalink)
Peter
My Truck - '96 RAM 3500 Laramie
Any updates?
Old 03-24-2010, 11:11 PM   #26 (permalink)
Torontocity's Avatar
some pics
i am pulling out the engine hopefully this week...Depending on weather...i have no garage... i got a Diesel torque converter made and i rather pull the motor than the tranny...will post full video soon as done.
Old 04-07-2010, 09:20 PM   #27 (permalink)
Job is almost done ...Rain came and hold me up. I'll be posting a new Video in a few days...
see all here Flickr: Torontocity's Photostream
Old 04-19-2010, 06:24 PM   #28 (permalink)
Tour of 300SD on Flickr - Photo Sharing!
Mopar to offer Diesel Swap kit for Wranglers Red EcoModding Central 8 08-09-2011 06:23 PM
63mpg in a 1986 Isuzu Trooper Turbo Diesel TheWildHippie Success Stories 18 08-10-2010 11:40 AM
Toronto Greetings (1994 Suburban w/ Mercedes diesel swap) Torontocity Introductions 10 11-24-2009 04:17 AM
Very Rare Chevy Blazer Turbo Diesel - SVO Conversion eco_generator For Sale 3 10-12-2009 09:38 PM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
