Old 08-03-2014, 12:06 PM   #61 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 17.09 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16 mpg (US)
Thanks.
As for the new tires, they throw off the odometer. But what should I calculate by? I read at one source that I should calculate by 1.09%, and yet Automobile-Catalog says the tires are 1.2% larger than stock.
Stock: P205/75R15
New: 225/70R15
Source 1: http://www.1010tires.com/Tools/Tire-...5R15/225-70R15
Source 2: http://www.automobile-catalog.com/ti...automatic.html
Old 08-03-2014, 12:34 PM   #62 (permalink)
What brake pedal?
digital rules's Avatar
Silver Streak-5M - '05 Toyota Corolla S
90 day: 42.41 mpg (US)
Use a GPS if you have one or can borrow one to calibrate the odometer/speedometer.
The Following User Says Thank You to digital rules For This Useful Post:
101Volts (08-03-2014)
Old 08-03-2014, 12:41 PM   #63 (permalink)
101Volts's Avatar
90 day: 16 mpg (US)
Now I have another reason to buy one. Thanks for that.
Old 08-03-2014, 12:58 PM   #64 (permalink)
What brake pedal?
You can also use mile markers along the highway, but would need at least 100 miles to dial in an accurate number.
Old 08-03-2014, 10:37 PM   #65 (permalink)
101Volts's Avatar
90 day: 16 mpg (US)
Thanks. I have access to a highway and to the time, It's just a matter of doing it.
Old 08-29-2014, 05:22 PM   #66 (permalink)
101Volts's Avatar
90 day: 16 mpg (US)
OK, Fill-up day.
Not much to say about the mods - I pumped the tires to 45 Hot now. But now I need to find what the actual mileage is VS odometer. I multiplied the 408 miles by 1.15 (To go in-between 1.09 and 1.2) which got 468.6 Miles and between 21 and 22 MPG on this last fill-up. That's in the neighborhood of 35 PSI in the tires for the whole tank.
I will say the car coasts a lot more now, at 45 PSI Hot.
I'm still thinking of changing the fan. And what else is, the fan in the Mercury we got is constant too, not on-demand so that may be changed some time.
Old 08-30-2014, 01:36 AM   #67 (permalink)
So, replace the fans on both. It's a fairly cheap mod and in some circumstances can increase efficiency from 3 to 5%.
101Volts (08-30-2014)
Old 08-30-2014, 10:17 PM   #68 (permalink)
101Volts's Avatar
90 day: 16 mpg (US)
I understand it reduces warm-up time.
Old 08-30-2014, 10:22 PM   #69 (permalink)
It does. And actually it also helps regarding efficiency improvements, since the engine would be wasting less fuel to get into the optimum operational temperature.
Old 09-02-2014, 06:15 PM   #70 (permalink)
101Volts's Avatar
90 day: 16 mpg (US)
I went on a trip today. The odometer read that I went 104.85 (rounded off) miles, I actually went 107.1 according to Google Maps. So, Multiplying by 1.022 gets close to the actual reading.
This also means the tires didn't make much of a difference MPG wise (For just one tank) to the last ones when run at the same PSI (35) but I did bump these new ones up to 45 Hot at fill-up time, and the previous tires said "35 PSI Max."
... I need to put other mods on than just the tires if I'm going to get past 25 MPG frequently. A new fan does come to mind and I wonder if replacing the air-pollution equipment would be of benefit, if it hasn't been replaced. Surely there are some CATs that are more efficient than there were in 1983.
I do still have the Diesel Conversion in mind (With the proper engine + Manual Transmission and 20 Gallon Diesel Tank = Instant 30+ MPG HWY in my mind.) but I'm thinking of doing some other things first.
1984 caprice classic, car modifications, classic car, ecomodding, hypermiling
