Old 08-26-2009, 12:30 AM   #11 (permalink)
What year is hyour eclipse? I have a 97 eclipse GST, and I was under the impression it had peak and hold type injectors. If yours has peak and hold, how did you get it working right, as I was under the impression peak and hold types had no solution as of yet.
Old 08-26-2009, 11:11 AM   #12 (permalink)
Yes, you have peak/hold injectors. I would imagine a 2g eclipse will work better since your speedo isn't a reed switch. The 1g speedo is very inaccurate so I don't see how you could accurately calculate MPG on a 1g without doing some other type of jim trickery.
