Old 01-13-2010, 05:29 PM   #1 (permalink)
meelis11's Avatar
Green frog - '97 A4 Avant 1.9TDI 81kW
90 day: 39.92 mpg (US)
Mixing a dose of LPG with diesel to improve power and economy
Hey,
I found this interesting article.
However, the magic comes in the addition of LPG to the diesel fuelling mix. The LPG is added in vapour form prior to the turbo (in turbo engines) or prior to the inlet manifold (in naturally aspirated engines). The LPG, comprising about 25 per cent of the diesel flow, burns along with the diesel in the cylinders. The combination of the diesel/LPG fuel gives the greater power output and lower emissions. The reduced running costs come from an improvement that is realised in diesel fuel economy – and the fact that LPG is a cheaper fuel than diesel.
It seems like promising thing if you have diesel engine. Unfortunately I dont have. Maybe some garage-inventors can make their home-brewed version?
Meelis
Old 01-13-2010, 07:38 PM   #2 (permalink)
LPG for diesel works like Nitrous Oxide for gasoline engines.
Been happening for a while and so far as I can find no real disadvantages apart from the extra complication and small loss of space for the LPG cylinder to go somewhere.
Pete.
Old 01-13-2010, 09:51 PM   #3 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Diesel performance guys do this for quick, cheap HP. What you are doing is making the engine a dual-fuel engine. Propane is nothing more than an auxiliary fuel. Propane won't compression-ignite. The injectors squirt some diesel into the chamber and it acts as a spark plug, blowtorching the propane to ignition. The propane, once ignited combusts very quickly, so if you use propane you can't use a lot of injection advance. Too much injection advance and you bend rods.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
Piwoslaw (01-18-2010)
Old 01-15-2010, 01:54 AM   #4 (permalink)
I managed to find someone who has actually done this addition / conversion.
The end result is an increase in power and a decrease in costs (about 7%) since LPG is cheaper than diesel with no reliability problems so far.
Pete.
Old 01-15-2010, 03:31 AM   #5 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
It's not quite like Nitrous use in a gasser, though... Nitrous is an oxidizer... you can also use it in Diesel engines. Propane is a fuel, and can also be used in gasoline engines.
I wasn't aware that propane won't auto-ignite under compression? Or did you mean under the compression that normally occurs in a combustion engine?
OK - LPG will auto-ignite at ~1000degF, so probably not going to happen in a normal combustion engine.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 01-15-2010, 03:32 AM   #6 (permalink)
Reference for the above post -
Old 01-15-2010, 04:53 PM   #7 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...auto-ignition point vs. CR?
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 01-15-2010, 09:10 PM   #8 (permalink)
Big Dave's Avatar
It all depends on the price of propane. Around here LPG cost maybe 20 cents a gallon less than taxed No. 2 diesel.
For every gallon of diesel you offset, you'll burn a gallon and a half of LPG.
4" Slam
Old 01-18-2010, 10:29 AM   #9 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
Could the reduced emissions be b/c there is LPG displacing some of the atmospheric air (mostly N and some O) going into the cylinder, creating less NOx?
Piwoslaw's Peugeot 307sw modding thread
Old 01-18-2010, 04:18 PM   #10 (permalink)
Big Dave's Avatar
I doubt that LPG displaces enough air to matter. Most street diesels run a lot of excess air.
4" Slam
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
Power Steering delete for fuel economy gain - anyone done it? bennelson EcoModding Central 51 10-03-2010 09:24 PM
Diesel Power Magazine Fuel Economy Shootout JQmile EcoModding Central 3 03-18-2009 10:23 PM
As I Had Thought Big Dave General Efficiency Discussion 54 09-03-2008 12:00 AM
Performance and Fuel Economy (Subaru's Diesel Impreza STI) SVOboy General Efficiency Discussion 9 03-06-2008 07:15 PM
