Old 10-13-2015, 10:45 AM   #41 (permalink)
Geoff - 5 speed swap - '02 Volkswagen Jetta GLS TDI
Diesel
Team Turbocharged!
90 day: 49.46 mpg (US)
Fusing Titanium - '19 Ford Fusion Titanium
Team Ford
90 day: 50.91 mpg (US)
So, I'm currently on my forth tank after TDIfest with the pan on.
The first tank after was 53.3, but it had about 400 miles highway driving.
Second tank was normal driving, 52.7
Third tank I was hard on the car again, only just broke 50
This tank I am on will be bad as well, as I was hard on it, and did a dyno run.
On the plus side, found out my car puts down 155bhp, and 298ft/lb of torque
The larger and much heavier wheels have a noticeable impact on my mpg when I'm not being nice to the car. The next tank, I will try to go back to hypermiling.
2002 Jetta GLS TDI 345k+ miles, all mods listed in description 156HP, 298FT/LB
The eclipse has retired, but I still like seeing it around
The Following 3 Users Say Thank You to Rango318 For This Useful Post:
aerohead (10-13-2015), BamZipPow (10-24-2015), deejaaa (10-13-2015)
Old 10-13-2015, 03:37 PM   #42 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
So roughly just above 15% improvement in mileage then? Seems like 5-15% is what is predicted for full on belly pan. Nicely done!
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 10-13-2015, 06:20 PM   #43 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
thanks for the update.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 10-13-2015, 11:25 PM   #44 (permalink)
Diesel
Team Turbocharged!
Team Ford
I would say the pan definitely helped. The larger tires have made the effect less noticeable, but I will soon be switching to my stock 15s for winter. Maybe I'll get a tank or two in before winter blend fuel and cold weather hits.
The Following User Says Thank You to Rango318 For This Useful Post:
aerohead (10-14-2015)
Old 10-15-2015, 04:23 PM   #45 (permalink)
Cd
Ultimate Fail
Cd's Avatar
That is one of the nicest looking non factory belly pans I have seen.
Looks stock.
Thanks for the pics.
Old 10-23-2015, 09:45 AM   #46 (permalink)
Diesel
Team Turbocharged!
Team Ford
A quick update. I filled up yesterday after managing to drive 1 full tank without beating on the car, or making any longer than usual trips. My normal before the pan MPG was anywhere from 52.5-53.3. This last tank was 55.35, so an improvement of 2 MPG, which also makes it my highest tank that didn't have any long distance highway driving, 877 miles on 15.846 gallons
aerohead (10-23-2015), BamZipPow (10-24-2015), deejaaa (10-24-2015)
Old 10-24-2015, 12:27 AM   #47 (permalink)
Not banned yet
deejaaa's Avatar
way to go!
Old 10-24-2015, 12:32 PM   #48 (permalink)
Diesel
Team Turbocharged!
Team Ford
Originally Posted by deejaaa View Post
way to go!
Thanks. I'm going to be attempting to do the same again this tank, not distance, but overall MPG. I have a trip I must take next weekend, so I'll be filling up Thursday night. If I can break at least 54.5, I'll be happy with the results. Now I need to find another bed liner to finish the pan.
The Following 2 Users Say Thank You to Rango318 For This Useful Post:
aerohead (10-24-2015), deejaaa (10-24-2015)
Old 12-05-2015, 03:40 PM   #49 (permalink)
Diesel
Team Turbocharged!
Team Ford
Been a little while since I've posted an update. My MPG has fluctuated between 50.7 and 52.2 over the last 4 tanks, so not very good IMO. I put my smaller and lighter wheels back on for winter at the end of my last tank. My current tank is looking to be better than my previous 4, even with the colder weather and winter blend fuel.
I've decided that come spring, I will not be putting on my heave 18 inch wheels again, and will be looking for a light weight set, probably 17's.
I'll post another update in a few days to let you know how the smaller wheels are doing with the pan. I never ran them with the pan, so this should give me a rough guess of improvement, even though it is cold outside.
aerohead (12-05-2015), deejaaa (12-05-2015)
