Old 02-22-2012, 11:06 AM   #41 (permalink)
Elle - '010 Element SC
one suggestion I would have about the rear window.
find a roof section at a junk yard. say rear edge of t-tops back and add the top and sides to the oem part. and have the glass close almost at the rear edge of trunk
think...
you would also get more headroom for rear passengers
ive also heard of people using a fiero front bumper on camaros with flushed in headlights.
Old 02-22-2012, 11:26 AM   #42 (permalink)
skyking's Avatar
Woody - '96 Ram 2500 SLT
90 day: 20.74 mpg (US)
Avion and Woody - '96 Ram 2500/5th wheel combo
90 day: 15.87 mpg (US)
Mine leaks back there.
At the front or back?
1996 Dodge 2500 Cummins Turbodiesel
Custom cab, auto, 3.55 gears
Old 02-22-2012, 01:53 PM   #43 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
Both.
Its not much of a problem now since it only rains about 4 time a year.
In eastern virginia it would rain 4 times a week.
I am pretty sure the back hatch is leaking where the hatch hinge bolts meet the sheet metal, because I already replaced the hatch seal and sealed it with 3M seal sealer and it had no effect.
For me the rear seats have been removed, one seat is being used for my LiFePO4 battery relocation and the other may become a water/methanol tank.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
Old 02-22-2012, 07:59 PM   #44 (permalink)
V8 guy
Pickups
Here is something you can use.
In the pic I placed a paint can on the tail light plastic to the trunk seal.
The paint can lifted the back glass about 7''.
skyking (02-23-2012)
Old 02-22-2012, 08:08 PM   #45 (permalink)
skyking's Avatar
Cool! IF you get a chance take a look at far out the bottom corners of the glass stick out into the wind on either side, when it is lifted like that.
Old 02-23-2012, 01:48 AM   #46 (permalink)
Schwinning!
Sven7's Avatar
The Anal Probe - '92 Probe GL
Team Ford
90 day: 35.92 mpg (US)
If the sides clear that's going to look nice. I hadn't expected it to look that good.
Originally Posted by Weather Spotter View Post
Nothing fell off so that is good.
Old 02-23-2012, 08:05 AM   #47 (permalink)
skyking's Avatar
If they don't, imagine the glass cut off to parallel the body line. That would let me build a nice gutter for water and narrow it up at the same time. I could build plug sides that sit in the factory gaskets, do them gloss black, little sealing welt at the fender edge.
Old 02-23-2012, 12:57 PM   #48 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 Golf
90 day: 51.68 mpg (US)
Somebody throw a template on that. The back edge of the spoiler looks a little high to my eye. I would do some careful mpg testing of the mockup to make sure you don't end up with something worse than stock, before doing permanent bodywork.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
The Following User Says Thank You to COcyclist For This Useful Post:
Cd (02-23-2012)
Old 02-23-2012, 02:04 PM   #49 (permalink)
Schwinning!
Sven7's Avatar
Team Ford
Poifect.
The Following User Says Thank You to Sven7 For This Useful Post:
oil pan 4 (02-26-2012)
Old 02-24-2012, 12:43 AM   #50 (permalink)
skyking's Avatar
Thanks sven. Cocyclist, that last little bit you see above the template as shown above simply unbolts from the glass. Looks like oil pan 4 hit a home run with the first swing of the bat
The Following User Says Thank You to skyking For This Useful Post:
COcyclist (02-24-2012)
