Old 11-16-2009, 01:38 PM   #1 (permalink)
Modding Ford Expedition
Hi there,
We own a Ford Expedition and I'd like to modify it to see what kind of improved gas mileage we can get.
*** Before I go further, please keep the flames and snarky comments to yourself. I realize this is a ridiculous vehicle from a MPG standpoint, but given the economy it is not one we are in a position to replace at the moment.
Anyway, its a 2005 2wd model and currently gets 13mpg city (my wife drives it) and 18mpg highway. I would love to get it to 20 and over highway and at least up to 15mpg in the city. I've been studying the Chevy Tahoe hybrid and it has a lot of mods to it for mpg that have nothign to do with the powertrain.
here are the mods I'm considering - feedback please:
1) remove roof rack (doesn't have crossbars - is it worth doing?). Tahoe hybrid does not have one.
2) remove spare tire and related jack tools. Does anyone use Slime as a preventative product or carry it in case of flats? With the size of these wheels, it just seems ridiculous to carry an extra one one around. Tahoe hybrid has runflats. FYI our current wheels are 18" wheels off of a lincoln navigator that look like this and are pretty flat on the face.
3) lower the ride height. the 03+ models are the same height whether 2wd or 4wd, but there is no reason for it to ride as high as it does. Are we likely to see an aero mpg gain on the highway? I wouldn't mind having the step in height be lower anyway and the springs are a little stiff on initial jounce, so maybe a progressive lowering spring may even ride better??
4) front air dam. Tahoe hybrid has a pretty massive one that hangs down fairly low. Ours looks like the one in this photo and you can see that the license plate needs to go and there is a decent lip to mount some lower material.
- would it be a good idea to mount a lower lip here or would it increase the size of the front end too much? If it would be, where can you get some material to mount here? Does anyone make some plastic to use for this purpose?
- What should I use to cover those huge lower holes (I believe they are for tow hooks on the 4wd model)? Might also try blocking that lower grill -- not sure if we need so much air intake.
5) re-map the throttle response? I can get more mileage out of it with a light foot, but for my wife it would be better of the throttle was remapped so that it didn't give as much throttle when you barely touch the gas. can this be done?
6) Gear ratio. We currently have a 3.73 rear diff ratio which could be lower. It cruises at around 2k rpms on the freeway. Due to cost and complexity, a gear change may not be in the cards, so what is the current thought on taller tires? Any benefit or do you lose it based on having to turn taller/heavier tires?
That's it for now - I really appreciate any and all constructive feedback!!
Old 11-16-2009, 06:38 PM   #2 (permalink)
econ00b
green car - '91 civic hb dx
Originally Posted by peakay View Post
Hi there,
Ill go through point by point
1) Roof rack bars, probly not worth it, will only reduce the frontal area by a few inches if it has no cross bars, and will leave holes in the roof to deal with
2) If you have AAA or something, go ahead and remove the spare and tools, I dont recommend using slime in auto tires though
3) Big YES to lowering, its one of the biggest things you can do to reduce frontal area. The underside and rear of the vehicle are where the biggest aero gains can be made, ties into number 4
4) Yes, a front lip would be a great idea, the less air that flows under the car to hit all the stuff hanging below the better. You could probly mod something like this from a dodge ram to fit . Coroplast would work to cover the lower holes. I would leave the lower grill unblocked, and block the upper one instead, just keep an eye on temperature to make sure it doesnt get too hot. If it does, remove a bit at a time until temperature is normal. Building some kind of full or partial belly pan would also give you good results, can search on here for some examples, coroplast is a popular choice of material.
5) Remapping the computer is actually pretty easy for domestics, the superchips flashpaq this one here will let you remap a few different ways for a reasonable price, check ebay and stuff too im sure you can find a used one for about $150. Just make sure you enter the correct tire size and stuff.
6) Taller tires would help, try and find ones in stock width with a higher aspect ratio to reduce weight gain.
Your goals are certainly attainable, and you should pass them easily. Have you read over the driving style tips and techniques? Also make sure you have your tires inflated to 35-40 psi, whatever the sidewall max is, you can go over the max, but its not recommended if you carry a lot of weight or tow regularly.
If your situation changes and you find yourself looking for a vehicle with utility for a cheap price, the old accord wagons will actually carry quite a lot and deliver decent fuel economy in stock form example
Good luck with your project! Keep us updated
Old 11-16-2009, 09:47 PM   #3 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
Air dam will help you a bunch on the highway, probably more than you will expect.
Old 11-17-2009, 11:56 AM   #4 (permalink)
Thanks Guys. It seems like you really like the airdam idea -- will have to look into that further. What I need is nice looking black plastic with a small 90 degree lip at the top (for fastening) that will also bend around the curve at the ends of the bumper. Any ideas? I don't think an airdam from another car will work nor colorplast.
Regarding the tires, I can't find any taller that are not wider. We already have tall but fairly narrow tires at 255/70/18. I assume we should just stick with those, eh?
So I think I am down to these mods in this order:
- remove spare tire and jack
- engine ecu tuning
- lower vehicle
- partial grill block
- airdam
Any other realistic ideas I am missing?
thanks!
Old 11-17-2009, 12:25 PM   #5 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
Slow down within reason. Get up to torque converter lockup speed, and then mosey along. The power needed to shove air out of your way increases exponentially as your speed rises linearly, so even a little slowdown yields big gains. But neither do you want anybody climbing over your backside because you're just a big moving speedbump.
Never stop. See that red light three blocks away? That's a long one, boy do you ever hate that pokey-slow light. If it's as long as that, no point in hurrying up to it, is there? Time it right and you're still moving when you get there - and there's some kinetic energy you didn't throw away, and don't have to burn more fuel to get back.
Those two are my favorites, but there's a sticky listing the 65+ things you can do and they all help. By the way - behavior modification is completely free.
You're not in front of me...
I'm 25,000 miles in front of you.
Old 11-17-2009, 12:45 PM   #6 (permalink)
Thanks elhigh. I do those things when I am driving...the dealer was astonished to see our front brakes had about 50% life left when we were in around 50k miles. However, my wife does not try to do this much, so I really need to make the car more efficient on its own.
Also, we take loooong drives in this car from California to Utah with kids and need to make the best time we can -- we simply are not going to go cruise the double nickel in 75 and 80 mph zones in Nevada and Utah. For this, I want to make the car as aero as we can get it for high speeds, but realize that most of our driving is local and that is where we need the most help.
Old 11-17-2009, 12:50 PM   #7 (permalink)
The Geo - '93 Metro
Do the aero mods that you already have listed, and then come back ot us.
Old 11-17-2009, 01:31 PM   #8 (permalink)
YJ - '89 Wrangler
FOCUS - '00 Focus ZTS
The Wife's Hot Rod - '09 G8 GT
Last 3: 23.22 mpg (US)
Be careful in lowering your 2wd Ford. If it has the twin I-beam front suspension you probably don't want to just cut your springs down. It will mess up suspension geometry. You want to find a kit that compensates for this.
Don
Old 11-17-2009, 02:22 PM   #9 (permalink)
chuckm's Avatar
Exploder - '02 Explorer xlt
Rolla - '02 Corolla ce
90 day: 44.43 mpg (US)
It's not a "mod" per se, but I'll strongly recommend getting a Scanguage before you do anything else. Your biggest gains at this point are to be had in modifying the nut behind the wheel.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Think you can hypermile? Ford contest will give the winner a car * MetroMPG Hypermiling / EcoDriver's Ed 6 08-04-2010 09:31 PM
2010 Ford Fusion Hybrid: Built for Ecodriving SVOboy EcoModder Blog Discussion 0 04-15-2009 06:50 PM
Ford Assembly Plant Tour and Museum (Detroit) RH77 The Lounge 9 09-25-2008 05:29 AM
Ford Motor Company Johnny Mullet General Efficiency Discussion 5 07-27-2008 07:39 AM
Ford, making money? It must be a mistake... SVOboy General Efficiency Discussion 3 04-28-2008 10:28 PM
