Old 09-26-2014, 04:40 AM   #1 (permalink)
Low budget tool making.
Hello,
for fiber composite parts it is important to make molding tools.
CNC molding tools are expensive so I decided to make the tool at the workbench.
You need a 3D geometry and cut-curves.
For symmetric molding tools, I used wooden templates to cut with a hot wire.
Then I cut styro plates.
Following pictures and the video gives yo a overview, how to make the tool.
Kind regards
Ulrich
Last edited by u.steinlechner; 09-26-2014 at 09:32 AM.. Reason: changed you tube link
The Following 14 Users Say Thank You to u.steinlechner For This Useful Post:
aardvarcus (10-06-2014), aerohead (09-26-2014), BamZipPow (09-26-2014), brucey (10-04-2014), fusion210 (09-26-2014), iveyjh (09-26-2014), mcrews (10-03-2014), MetroMPG (09-26-2014), oldtamiyaphile (09-26-2014), RedDevil (09-26-2014), redneck (09-26-2014), RustyLugNut (09-27-2014), sendler (10-04-2014), Vekke (09-27-2014)
Old 09-26-2014, 08:39 PM   #2 (permalink)
8 Thanks and no comments?
Have you seen http://ecomodder.com/forum/showthrea...eat-22529.html? One of our members is (slowly) building a whole car that way.
u.steinlechner (09-27-2014)
Old 09-27-2014, 05:22 AM   #3 (permalink)
It will work
Yes, I saw this and I think it will work.
Ulrich
Old 09-27-2014, 05:32 AM   #4 (permalink)
Details
In this photo gallery you will find some more details.
Xanon Bionic Electric Vehicle - Xanon-X3 Werkzeuge Formenbau - Werkzeuge und Formenbau
The inner airbox and expansion chamber were made by lost tools.
The Following 3 Users Say Thank You to u.steinlechner For This Useful Post:
aerohead (09-27-2014), BamZipPow (09-27-2014), freebeard (09-27-2014)
Old 09-27-2014, 12:06 PM   #5 (permalink)
Thanks for the pictures and links. Nice work.
Old 10-03-2014, 04:14 AM   #6 (permalink)
Emerald - '97 Honda Civic CXi
90 day: 40.13 mpg (US)
I've done something similar in the past, but skipping the 'wooden template' step by simply using a projector to project sections onto the material (calibrated by use of a ruler matched to the projected image), then tracing with a texta.
Initially doing the cutting with an electric jigsaw, but that created a *lot* of nuisance dust - you ain't seen nuisance dust 'till you've seen polystyrene nuisance dust, the stuff electro-sticks to *everything* . Turns out a snap-off blade utility knife with the blade fully extended, and held at a fairly low angle to 'drag' through the polystyrene, works much better and produces a nice clean cut (and doesn't produce the nasty gasses that a hotwire does).
For what I was doing I didn't need the precision you get from u.steinlechner's more traditional method, but I reckon you could get the best of both worlds (precision and even less cost) by printing the profiles on large format paper at an office supply store, and using a utility knife for the cuts.
I must say though, the hot wire produces some very nice circular holes
The Following User Says Thank You to Madact For This Useful Post:
aerohead (10-03-2014)
Old 10-03-2014, 11:43 AM   #7 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
here's a comment: "WOW ....no really WOW!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 10-03-2014, 03:27 PM   #8 (permalink)
An vintage tool from the 60s. It was US$1.99 at a second hand store, and uses 2 D-cells.
Try a knife blade instead of a saw blade in the jiggler saw. It works great on corrugated cardboard, and should do well on stryofoam.
Old 10-04-2014, 12:48 AM   #9 (permalink)
90 day: 31.19 mpg (US)
I really like the construction methods of carBEN. Too bad nature conspired against it! I am glad that was not worse!
I bought the nichrome wire to make a wire cutter, but connecting it to my battery charger did not do anything, although I have charged batteries in two different Civics with it.
Old 10-04-2014, 12:47 PM   #10 (permalink)
cutter
The late Bob Parsons had a 'VARIAC',variable-voltage,DC power supply that he used for hot-wiring.It's like a larger version of a scale model train transformer.
Once you dial in an acceptable output,you're golden.
Alexander Sport Air used them at Oshkosh during their annual Fly In workshops.
I found one in Dallas at the monthly electronics swap meet for $35.
