Old 02-19-2009, 12:52 AM   #11 (permalink)
Originally Posted by TestDrive View Post
I definitely don't follow the part about rise.
I've simply found that it's hard to judge intuitively how much speed will be required to coast to the top of a hill. I've come to realize that this is because the vertical distance is not a function of velocity, but of velocity squared.
Let see how well I'm doing with the rest.
Let's assume the scale of your regular dial speedometer reads 0-110 mph.
Let's also assume that the needle sweep from 0-90 mph is 90*.
What do you want the needle sweep from 0-60 mph to be?
  1. 60*
  2. 40* (my understanding)
  3. Some other number of degrees. (If so, what number?)
If the answer is 40*, I'd don't see why you'd need/want any additional scale markings other than km/h.
Yes, 40 degrees.
The speed markings (both mph and kph) would be on a parabolic scale. They would start out squnched together and spread apart as the speed went up. The rise (in feet/meters) would be a linear scale, just like the current speedometer.
What I think I'm going for is trying to get a better intuitive grasp on how much kinetic energy I have and how much drag I'm experiencing. Maybe it won't do a whit of good, or maybe I'll be surprised.
Old 02-19-2009, 01:51 PM   #12 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
There are so many things that depend on getting to the top of a hill besides starting speed. Air temperature, wind speed and direction, tire pressure, road surface condition, current viscosity of lube in tranny/bearings/engine etc...
Winter daily driver, parked most days right now
Summer daily driver
Old 02-19-2009, 03:57 PM   #13 (permalink)
This is true. And when I can 'feel' my kinetic energy, it will free up brain for thinking about them.
Old 02-19-2009, 11:57 PM   #14 (permalink)
I just made my first mockup in Inkscape.
I can't remember the last time I exceeded 80, so the range shouldn't be a problem. It's already 15 mph over the highest speed limit here anyways!
Old 02-20-2009, 12:04 AM   #15 (permalink)
I realized something else as I was explaining the merits to a friend: it also tracks the relative braking distance at that speed.
Old 02-20-2009, 01:39 AM   #16 (permalink)
Eliminated the crowding on the lower numbers (anyone ever see a <15 mph limit?)
Old 02-20-2009, 01:58 AM   #17 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
Yes, I see sub-15 MPH limits, but not a lot of speed traps to go with them. I'd trust my estimate of my running speed.
