Old 11-29-2009, 11:32 AM   #1 (permalink)
Two_Weeks's Avatar
Luigi - '94 Uno 60D Start
90 day: 45.18 mpg (US)
Modify or not?
A couple of areas on my car concern me with regards airflow. Tell me if you think these areas could do with being modified, or should i just leave alone?
Door Handles
Scuttle panel
I can reposition the single wiper centrally which should help. I live in England, there would be no point removing it and then replacing when needed!!
Let me know what you think.
Thanks.
Old 11-29-2009, 11:47 AM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
In case you haven't already done so, a grill block and Kamm back would be more beneficial.
Most likely, air will just slip right past those gaps. If the gaps were at the front of the car ( such as below the hood or headlights, they would have more effect on drag.
I'd fill them in anyways. It would seal out some of the road noise and keep you warmer.
Welcome to the site !
Old 11-29-2009, 12:49 PM   #3 (permalink)
Wanderer
Sorrow Six Star's Avatar
Winona - '86 XT DL
what is that car? I like what I am seeing so far
the indented handle is probably a factory aero idea already. beats adding surface area with the door handles sticking out...
the wiper is easy.... put in a switch to the swicthed power to the motor then you can stop it where ever you like!
Originally Posted by bgd73 View Post
Legends are legends after all..
Old 11-29-2009, 01:25 PM   #4 (permalink)
Two_Weeks's Avatar
It's a Fiat Uno. I beleive some of the small Peugeot's also have these type handles.
Why didn't I think of that???? Nice job.... Oh so simple.....
Old 11-29-2009, 08:59 PM   #5 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I like saying "skut ul" with a british accent!
Old 11-29-2009, 11:02 PM   #6 (permalink)
Wanderer
Winona - '86 XT DL
you're a looney...
Old 11-29-2009, 11:07 PM   #7 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Nope! Not far off, but I'm still south of the Canadian border!
Old 12-05-2009, 04:28 PM   #8 (permalink)
sticky's
I recommend you check out the modification sticky's listed near the top of the forum page.
You'll be able to appraise where your car is now,and what potential mods might mean to you.
Old 12-06-2009, 07:14 AM   #9 (permalink)
Two_Weeks's Avatar
Sure. Have done, just wanted some thoughts on these particular areas, and whether modifying would benefit me.
Old 12-07-2009, 06:20 PM   #10 (permalink)
leave 'em alone
I'd look elsewhere for mods.
You need to do the pick and shovel work before you start polishing buttons.
What would you do to all-out modify (ecomod) a Honda Insight (gen 1)? MetroMPG Hybrids 25 11-26-2009 12:00 AM
Modify Alternator Output Voltage Coyote X DIY / How-to 2 02-24-2009 12:06 PM
Modify an old 60s Cadillac for 4 or 6 cyl? amcpacer EcoModding Central 31 12-10-2008 11:24 AM
