Old 08-16-2011, 04:46 PM   #11 (permalink)
"Inconceivable"
moorecomp's Avatar
My ZX2 - '99 Escort ZX2
Team ZX2
90 day: 40.5 mpg (US)
Her RAV4 - '011 Rav4 4x4
90 day: 24.98 mpg (US)
Originally Posted by Floordford View Post
Had to do some digging but I found that my injectors also run off of a central red wire. But they also power other things after the injectors off that same wire. I may try a crude toggle switch to see if it throws a CEL. If it does its back to the drawing board. If im good then ill need to find a normally closed momentary push switch that can take that current all the time.
If you go close to the injectors, you will be able to get the wire that feeds only the injectors, further up the harness is where it feeds other things also. Mine was the same way.
moorecomp
Mancelona, MI
Old 08-17-2011, 01:01 AM   #12 (permalink)
Muscle Car Modder
Floordford's Avatar
QuikSilver - '00 Mustang GT
90 day: 24.7 mpg (US)
Yeah it powers certain things before the injectors and things after them too. So im not sure if cutting off power to the injectors will throw a CEL. I may need to sit down and stare at the schematics for a while and come up with a bypass that will let the power stay on to all the senders and sensors but cut fuel injector power.
2000 Mustang GT
273hp/ 309ft.lbs.
Cd 0.36 Im working on it
