11-07-2017, 02:35 AM
i should weld
A Montana outfit thinks they have the secret to inducing lean burn on <2005 cars.
What We Do
This outfit thinks they know how to induce 18:1 lean burn with emissions improvements (including reduced NOx somehow) using an aerodynamic device in the throttle body.
2007 Kia Spectra LX, front wheel drive (as all of them), 2 L, 5 speed manual. CEL lit
11-07-2017, 02:45 AM
The Gadgetman Groove by another name.
Idiots. Almost all intake manifolds for EFI are "dry"; fuel is injected adjacent to the intake valve so their "turbulence" does little or nothing. And for the throttle-bodies I fail to see how this would help either.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
11-07-2017, 08:26 AM
I don't think so.
11-07-2017, 04:58 PM
i should weld
Yes, idiots absolutely. It's a pretty sh!t little piece of kit. It won't do what's claimed. Surely, if the concept works, a rifled wall behind the TB would be even better. But it's not likely to work.
11-07-2017, 06:55 PM
Thalmaturge
Unicorn corral here we come.
11-07-2017, 09:17 PM
i should weld
Yeah, it's pretty much bull****.
11-07-2017, 09:56 PM
Are you sure this should be in the unicorn corral? I am pretty sure he wouldn't make up the part about the "complete elimination of noxious gas emissions".
And everyone knows that Q-jet carbs can't be turned upside-down like Holley's and Edelbrock's
11-07-2017, 10:40 PM
It may eventually induce a lower fuel amount to be injected, but since that device is a restriction to the airflow I wouldn't call it lean-burn.
11-07-2017, 10:52 PM
#9 (permalink)
i should weld
Fairly sure it's a DE-restriction, at least from what I've seen...
11-07-2017, 11:15 PM
#10 (permalink)
I haven't seen much about it, but anyway, as long as such de-restriction could cool down the intake stream it might then lead to a leaner burn without an increase to NOx emissions. But it would still be impossible to eliminate NOx at all.
