Old 02-18-2008, 07:26 PM   #1 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
more papers (aerodynamics links)
Here are couple of papers that might be of some interest to you.
Micro-vortex generators
Trailer aerodynamics
SAE pneumatic aerodynamics
Drafting and more trailers aero
Boundary layer separation
AIAA VG
SAE pickup tailgate paper (same principle as a spoiler)
Contribution to drag
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 02-19-2008, 10:13 AM   #2 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 70.97 mpg (US)
We need to collect the aerodynamic articles links on this and previous threads onto a dedicated sticky thread for quick reference so they don't get lost or buried.
aerocivic.com
Old 02-19-2008, 10:23 AM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Yeah, I was just thinkin the same thing.
Old 02-19-2008, 12:51 PM   #4 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
I concur on the sticky-icky of the aero stuff. Maybe Ben (SVOboy) woud have some time for that. If not, then I could find some time to lump them together I guess.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 02-19-2008, 03:04 PM   #5 (permalink)
H4MM3R's Avatar
Rear Aero
here is a picture. Of what a good rear of the car should look like for low drag.
Old 02-19-2008, 04:56 PM   #6 (permalink)
Moderator
The diffuser is way to short and it's angle to steep on this picture. It's far from optimal.
Old 02-19-2008, 05:26 PM   #7 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
I agree, way to steep....
Angle will greatly depend on height and length...
Check and see if your library has this book
Race Car Aerodynamics: Designing for Speed by Joseph Katz. While some of that won't apply to your typical car... There's interesting discussion on height/length ratios and front/rear shapes....
Another problem with saying that rear end is ideal (I know it wasn't explicitly stated) is that there's a lot of interaction between the side and bottom. Yes, ideally a cone is what you want - but you're not going to find the same flow speed under and next to a car... To deal with that, you'd add vertical winglets that extend the side of the car while the diffuser does it's magic under the car.
The wing strakes and side portion in this diffuser is close to what I'm getting at...
Challenge me, or correct me, but don't ask me to die quietly.
Old 02-19-2008, 08:19 PM   #8 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Good find, tas. I've used the tailgate paper to enlighten three different masses.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 02-20-2008, 07:20 PM   #9 (permalink)
Moderator
Here's a REALLY good one.
The Influence of Aerodynamics on the Design of High-Performance Road Vehicles - Part 1
The Influence of Aerodynamics on the Design of High-Performance Road Vehicles - Part 2
5th generation civic hatchback - improving aerodynamics AndrewJ Aerodynamics 383 05-15-2012 08:40 PM
Aerodynamics Seminar # 6 - by Phil Knox MetroMPG Aerodynamics 21 02-17-2010 11:26 PM
Aerodynamics Seminar #1 - by Phil Knox MetroMPG Aerodynamics 5 07-12-2008 04:12 AM
Aerodynamics Seminar # 5 - by Phil Knox MetroMPG Aerodynamics 4 01-29-2008 01:41 PM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
