Old 09-20-2011, 01:25 AM   #181 (permalink)
Tenderfoot
ChazInMT's Avatar
MagMetalCivic - '04 Civic EX
90 day: 37.18 mpg (US)
Morelli Shape.
Ha. Thought I'd bump this thread since it came up in Aero Temp C discussion.
Old 09-20-2011, 09:50 AM   #182 (permalink)
I have not read all 19 pages, just offering this overlay up for discussion and reference.
Industrial Design pictures by kach22i - Photobucket
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
ChazInMT (09-20-2011)
Old 09-20-2011, 12:33 PM   #183 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Thanks for that. I think the challenge with both the Morelli and the ideal profile is neither one accounts for the wheels. The Morelli designed "banana" car had actual wheels (and engine cooling) and therefore is realistic. Obviously, the wheels have to be accounted for, and if outboard wheels are used, then the interaction between them and the main body need to be taken into account.
Old 09-21-2011, 09:58 PM   #184 (permalink)
Originally Posted by neilblanchard View Post
thanks for that. I think the challenge with both the morelli and the ideal profile is neither one accounts for the wheels. The morelli designed "banana" car had actual wheels (and engine cooling) and therefore is realistic. Obviously, the wheels have to be accounted for, and if outboard wheels are used, then the interaction between them and the main body need to be taken into account.
amen.
Old 10-06-2011, 06:52 PM   #185 (permalink)
Morelli
It's extremely important to look at the tranverse cross-sectional view of this form.If you're doing a body in white vehicle,you'll incorporate the elliptical cross-section ( you must ) which is part of the forms performance.
With respect to modifying existing passenger vehicles to this 'solution,' it's going to be hard to pull that off.
Otherwise it's great!
Video: active aero (grille block) via shape memory alloy MetroMPG Aerodynamics 7 01-30-2010 11:21 PM
Video: clever, simple demo of teardrop shape -pointy end first vs. blunt end first MetroMPG Aerodynamics 10 03-12-2009 08:48 PM
Diesel electric kit car, anyone? R. Q. Riley's latest takes shape (and looks good!) MetroMPG EcoModding Central 11 10-07-2008 02:52 PM
Strange OEM Aerodynamic Shape (longitudinal roof indents) LostCause Aerodynamics 17 03-19-2008 11:26 PM
I need molding s2man EcoModding Central 4 03-15-2008 12:16 PM
