Old 10-21-2008, 06:34 AM   #1 (permalink)
Eco Noob
Doofus McFancypants's Avatar
Red Rover - '01 Altima GXE
90 day: 30.07 mpg (US)
Morning Commute Observation
This morning i came into the office early ( 6AM). it was early enough i braved the Highway for the drive (I75 into atlanta for about 12 miles). Usually i avoid the highway like the plague ( it is really odd seeing 8 southbound lanes STOPPED during rushhour).
I have done a pretty good job of tracking out the surfece streets to get be to and from work the best.
So this mornings commute - when i checked the Scangage TRIP - Lo and behold my commute MPG was 41 !!! this is way over the typical morning commute of about 32 ish. So i start thinking that i need to leave for work earlier and reap the highway MPG rewards...
But then i look at the total gallons used.. and total gallons of 0.42 compared to the surface street route of 0.35 gallons. ( the highway is actually MORE miles than the surface street)
So maybe the highway is not actually the best way to get to work - although from a pure MPG it is better in one respect - in another respect i can make the same trip with less gallons going a different way.
Has anyone else seen this in thier commute? the "Best MPG" is not actually the best way to take overall?
Steve
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
Old 10-21-2008, 09:40 AM   #2 (permalink)
BBsGarage's Avatar
BBsRide - '06 Corolla CE
90 day: 31.64 mpg (US)
with a 54 mile commute, the hy-way is the only way for me
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 10-21-2008, 10:11 AM   #3 (permalink)
EcoModding Newbie
Parachute - '03 Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Neon Highline baby!
90 day: 31.39 mpg (US)
I have the same dilemma, for the last part of my drive I can take the by-pass and get to work in less time, or go down the main street for the shortest distance, but takes more time as the city is a firm believer in unsyncronized stop lights... From what I can tell if I get lucky with the lights then the city route uses less gas. But on average I use slightly less gas using the by-pass and it always takes less time.
Although its fun to get high mpg numbers really we should be trying to lower the amount of gas we use.
Ian
Old 10-21-2008, 10:43 AM   #4 (permalink)
Puddles - '95 Metro LSI
90 day: 39.52 mpg (US)
Spec Miata - '91 Miata Club Racing
Scooter - '05 Metropolitan
Monstro II - '99 Ram 1500
Kassia - '01 Miata LS
Precious - '97 3500 Silverado Dually
Steve
I have the opposite occurence. It's less mileage to take surface streets capped at 30-45mpg, but given the reduced speed and the fact that I won't feel obliged to do 80mph like on the freeway, the mileage is way better, and hence so is my usage. It just takes me an extra 10-15mins or so.
that said, its a much less stressful commute, especially if i leave myself enough time to take it. Only a few traffic lights and maybe a half dozen 4 way stops (which I prefer as I can roll on through rather than wait for 5+ mins)
Old 10-21-2008, 10:46 AM   #5 (permalink)
Originally Posted by IndyIan View Post
unsyncronized stop lights... Ian
meaning they are not timed to your MPH so you cant roll through them all. What is the POINT of this? I have noticed quite a few communities local to me that are setup this way, it is really frustrating.
The other issue I have is at +2mph over the limit and tiny little geo metro brakes the yellow lights on a highway are REALLY short. I think they're set to assume you're doing +10mph over the limit and you can get through them in time. I cannot, and I can barely brake in time.
Old 10-21-2008, 12:24 PM   #6 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
When I go downstate and back, I can get better mpg taking the old side road rather than the freeway. On the freeway, even when I would drive the max speed limit of 70, Id have 90% of people blowing past me so I like the side road better, even if it takes a little longer. As a bonus, I found the side road is 5 miles shorter than the freeway so still less gas is used.
Winter daily driver, parked most days right now
Summer daily driver
Old 10-21-2008, 02:22 PM   #7 (permalink)
Because stopping cars solves all problems! Congestion, pollution, even crime rate. Just make all cars stop for a while, and your community will be a paradise!
...Or so a lot of city councils/planning boards seem to think...
-soD
Old 10-21-2008, 08:44 PM   #8 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Taurus GL (Sedan)
90 day: 20.27 mpg (US)
I have an 8-8.5 mile commute one-way. I usually take the expressway because I can keep a constant throttle and hover at 55-60, about 1.75-2 RPM.
They just reopened the bridge that was under construction, so now I can take this route:
It's only a half mile less and takes longer, but I drove it for the first time today, and hit EVERY single red light. This might seem bad, but that means I can stay at 30-35 MAX (1.5-1.75 RPM) and accelerate as slow as I want to and I try to let off the gas as far back as possible. I know it seems like it might cause lower MPG to go slower and take longer, but because I have lower RPMs I think it might be more fuel efficient. I don't know for sure, but I though it was worth posting... I really need to get a SGII or MPGuino.
Old 10-21-2008, 10:09 PM   #9 (permalink)
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
Absolutely indispensable.
More choices...
Old 10-21-2008, 10:16 PM   #10 (permalink)
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
I have run into the the MPG vs total gas used because of carpooling.
My wife's car economy dropped because she was doing short, cold-engine trips, to a co-workers house to meet to car-pool.
Yet, she was only using a little more that HALF the gas she was before!
MPG is only a measure of success when all else is even. Total gas used is the best measurement for conservation!!!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Best morning commute to date !!! 33.3 Doofus McFancypants Success Stories 0 09-05-2008 07:42 AM
Random commute pics Lazarus The Lounge 26 06-30-2008 09:59 AM
How was your (bike) commute today? igo Alternative Transportation 23 06-26-2008 07:33 PM
Suggestions on how I can improve my MPG on my commute?? regor Hypermiling / EcoDriver's Ed 4 06-09-2008 02:03 AM
78mpg commute to work this morning (Honda Insight) budomove Hypermiling / EcoDriver's Ed 26 03-16-2008 01:42 PM
