Old 04-04-2018, 07:55 AM   #21 (permalink)
Another thread to read.....
Crosswinds are always an issue. I ran FoilSim (from NASA) to get a feeling of sideforce (lift) using ballpark numbers. It's not hard to develop a couple hundred pounds sideforce from very small crosswinds. I know about tests done with storm strips and would like to be able to try that concept out if needed.
This guy went 200 at Bonneville with a little over 100hp:
Tom Mellor Triump BMST 2016 by Frank, on Flickr
He spent a lot of time on the details. Wheelbase is extended and he used a very narrow swingarm/wheel combination which allows gentle curves. His front wheel is totally enclosed (not allowed by most sanctioning organizations) but I'm sure that helps too.
thanks,
Frank
The Following User Says Thank You to Frank For This Useful Post:
aerohead (04-07-2018)
Old 04-07-2018, 12:33 PM   #22 (permalink)
truncation and drag
Kamm's asymmetrical wing section (much like a Clark-Y),with its aft section chopped off in 7 contiguous,equal-length segments registered a drag increase of:
*14%
*135%
*166%
*204%
*245%
*288%
*333%
Kamm's symmetrical airfoil,of 6-different aspect ratio configurations, created by shortening the aft portion,plus the airfoil,with no aft section at all registered:
*0%
*109%
*146%
*192%
*246%
*338%
*892%
Kosin and Lehmann's streamline body of revolution,chopped off in 10% increments registered drag increases of:
*0%
*3.03%
*12.12%
*28.8%
*59.1%
*200%
*256%
*330%
*425%
*567%
These are just naked bodies,in free flight,with no wheels or anything else attached,but you can clearly see the drag penalty as the pressure drag builds from each successive truncation or shortening.
Frank (04-13-2018)
Old 04-08-2018, 06:39 AM   #23 (permalink)
sendler's Avatar
90 day: 103.51 mpg (US)
Ninja 250R SE Green - '09 Kawasaki Ninja 250R SE
90 day: 65.9 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
Kawi Ninja650 - '07 Kawasaki Ninja650
90 day: 54.85 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 103.38 mpg (US)
90 day: 81.28 mpg (US)
What is the ratio of the Kosin and Lehmann's streamline body of revolution? Is it exeptionally long? Why does it exhibit much better truncation performance?
The Following User Says Thank You to sendler For This Useful Post:
aerohead (04-18-2018)
Old 04-18-2018, 01:53 PM   #24 (permalink)
ratio/why
Their streamline body is 14.5:1 fineness ratio.(think fuselage)
As a streamline body of revolution, it has the best sectional density and pressure/velocity profile of all shapes,hence 'streamline' body.
No wing section can compete with a streamline body for drag on a frontal area-based comparison basis.They are quite literally 'ideal' in shape.
Old 04-18-2018, 06:00 PM   #25 (permalink)
Ecomuggler
90 day: 36.05 mpg (US)
90 day: 36.32 mpg (US)
Frank and Aerohead, do you know what images you posted in #5 and on? Photobucket ate them!
aerohead (04-21-2018)
Old 04-21-2018, 12:44 PM   #26 (permalink)
ate
Mine were probably based on the symmetrical wing section table Freebeard was able to salvage.And the table I created from the FKFS research (Fachsenfeld and Kamm),and Hoerner's fairing tables.
I can't post any of them anymore.I've lost access to over 700-images and thousands of hours and dollars to create them since 2007.
Gotta love venture capitalists!
Old 04-21-2018, 01:22 PM   #27 (permalink)
One of these then?
Walk without rhythm and it won't attract the worm. --fatboy slim
_________________
aerohead (04-21-2018), Frank (04-21-2018)
Old 04-21-2018, 01:27 PM   #28 (permalink)
these
Yes,3rd from left on bottom row survives,but there were a couple I did later which only existed at PhotoBucket.
Frank (04-21-2018)
Old 04-21-2018, 03:03 PM   #29 (permalink)
Makin' it easy for the lurkers:
_________________
Old 04-21-2018, 03:30 PM   #30 (permalink)
Mine was the same bike as in post #18 except an earlier version (pic in #5) had batteries in saddlebags. I found I wasn't using the range (100 miles) so redid the system and eliminated the saddlebag batteries. I can dig out a pic if you like but I'm not sure if it would be helpful.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
