Old 04-17-2015, 08:40 AM   #11 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I'm using t_vagos code without any issues.
I remember some tests that I've made with 0.86 code but there was indeed some issue that required code changes for different clocks. t_vagos code needs that settings too, but it's one time thing. You should make the changes needed before uploading the code to your ATmega chip.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 04-17-2015, 07:13 PM   #12 (permalink)
Civic VX - '92 Honda Civic VX
Which version of t_vago's code are you using? 20140512 - mpguino_1.92_tav.zip or maybe something else? Did you have to modify it at all?
It looks like I'd need to comment out
Code:
#define use20MHz true
as well as
Code:
#define useChryslerMAPCorrection true
would there possibly be anything else I might need to do to load this t_vago code on a 16MHz Arduino (atmega328)
Old 04-20-2015, 04:18 AM   #13 (permalink)
AndrzejM's Avatar
I'm using 20140512 - mpguino_1.92_tav.zip code with MPGuino build accordingly to the attached diagram.
I'm using 20MHz crystal, with 3 standard buttons, legacy LCD.
I needed to comment unused features and that's all I've done to the code.
