Old 06-30-2011, 01:38 AM   #1 (permalink)
MPG calculators
I've seen the Ecomodder one, but it doesn't have anything about what size engine, which doesn't make sense to me. What ones are recommended that have engines?
Old 06-30-2011, 10:28 AM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...re: ScanGauge II™, you enter the engine size in liters (ie: 305 cid = 5.0 liters) as one of the initial "setup" steps.
Old 06-30-2011, 12:15 PM   #3 (permalink)
I'm talking Internet links, not in-car.
Thanks
Old 06-30-2011, 02:28 PM   #4 (permalink)
...beats walking...
...like the one here, under Tools?
...it doesn't need engine size because it's working backward from combined aerodynamic and rolling resistance loads to estimate needed HP, and then equates that to the usable power available from gasoline.
Old 06-30-2011, 03:56 PM   #5 (permalink)
Yes, and yes I understand what it's calculating. The thing I don't get is what if it was a 454 ci versus a 98 ci engine doing the work?
And, here's what I'm trying to get at:
I put in the number guesstimates for the Ranchero and get 32 mpg @ 65 mph, 36 mpg @ 60 mph, etc. How "real world" are these figures? If I could get ~40 mpg out of the Ranchero at freeway speeds, I'd do it. If that's not likely, I'll go with the lightweight, more aerodynamic single-seater version and hope to get ~60 mpg.
Thanks
Old 06-30-2011, 04:12 PM   #6 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 CJ7
You would adjust the engine efficiency for the range you would be running the engine in.
A larger engine would be less efficient at the same power load as a smaller engine.
Add to that no two engines are the same even if they are the same displacement, year, options...etc.
Old 06-30-2011, 04:24 PM   #7 (permalink)
TheEnemy's Avatar
Your talking about the Ford Ranchero?
Does it have an electric, clutch or direct driven flex fan?
Punching my best guess into the calculator I come up with a max of 22mpg between 35 and 45 mph. That is assuming you have a clutch fan, and a standard transmission.
weight 3500 lbs
crr .008 (a bit low I think)
Cd .45 (typical for a truck)
frontal area 20ft^2
Engine efficiency .20
Drivetrain efficiuency .85
Paracitic overhead 5000 (those fans really pull power)
Old 06-30-2011, 04:28 PM   #8 (permalink)
Okay, so how does one go about estimating the efficiencies of different engines?
It's an estimator, so that seems like splitting hairs.
The point being, I can't find the MPG estimator I used the other day.
Old 06-30-2011, 04:29 PM   #9 (permalink)
...beats walking...
...in different post, he stated the weight would be closer to 2400 lbs.
...and, transmission GEARING and AXLE make a huge differential; geared one way, the engine could make almost full HP at highway speeds but get lousey milage; geared differently, it could just barely exceed the HP needed at highway speed and get great milage, but couldn't pull a sick Grandma off her rocking chair if she was dead.
Old 06-30-2011, 04:34 PM   #10 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Remember the estimator gives good numbers for steady state, level, no wind cruise. Add the real world- stops and starts, grades, winds, etc. and one should knock at least 10% off the estimator's cruise value for what you'll realistically get (excluding P&G and whatnot).
