Old 03-29-2015, 02:35 AM   #1 (permalink)
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
MPGuino with Arduino Uno help
Hello folks I am really stuck and clueless with this one.
I went to the MPGuino wiki and copied the whole code but when I paste it and try to upload it to my uno I get a long list of errors.
I am truly clueless when it comes to coding. I have no issue with building the hardware.
Is the code listed on the wiki not compatible with the Uno?
If it is I would GLADLY paypal someone to correct it so it will just load on my Arduino.
I have searched all over for some kind of MPGuino for dummies to no avail.
Any help would be super appreciated!
If screenshots of all my errors is helpful I will certainly post them.
Thank you!
1998 LX with a full HX swap + VX transaxle.
Old 03-29-2015, 05:38 PM   #2 (permalink)
Here's the list of errors I get when compiling.
Arduino: 1.6.1 (Windows 7), Board: "Arduino Uno"
sketch_mar29b.ino:51:17: error: conflicting declaration 'typedef uint8_t boolean'
In file included from sketch_mar29b.ino:51:0:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:117:14: error: 'boolean' has a previous declaration as 'typedef bool boolean'
typedef bool boolean;
sketch_mar29b.ino:91:15: error: 'prog_char' was not declared in this scope
sketch_mar29b.ino:91:27: error: 'str' was not declared in this scope
sketch_mar29b.ino:397:1: error: 'prog_char' does not name a type
sketch_mar29b.ino: In function 'void setup()':
sketch_mar29b.ino:403:2: error: 'displayFuncNames' was not declared in this scope
sketch_mar29b.ino:432:44: error: 'getStr' cannot be used as a function
sketch_mar29b.ino:434:44: error: 'getStr' cannot be used as a function
sketch_mar29b.ino: In function 'void mainloop()':
sketch_mar29b.ino:541:37: error: 'getStr' cannot be used as a function
sketch_mar29b.ino:549:42: error: 'getStr' cannot be used as a function
sketch_mar29b.ino:553:45: error: 'getStr' cannot be used as a function
sketch_mar29b.ino:559:23: error: 'displayFuncNames' was not declared in this scope
sketch_mar29b.ino:559:47: error: 'getStr' cannot be used as a function
sketch_mar29b.ino:564:42: error: 'getStr' cannot be used as a function
sketch_mar29b.ino:569:23: error: 'displayFuncNames' was not declared in this scope
sketch_mar29b.ino:569:47: error: 'getStr' cannot be used as a function
sketch_mar29b.ino: At global scope:
sketch_mar29b.ino:628:15: error: redefinition of 'char* getStr'
sketch_mar29b.ino:91:8: error: 'char* getStr' previously defined here
sketch_mar29b.ino:628:15: error: 'prog_char' was not declared in this scope
sketch_mar29b.ino:628:27: error: 'str' was not declared in this scope
In file included from sketch_mar29b.ino:49:0:
sketch_mar29b.ino: In function 'void LCD::init()':
sketch_mar29b.ino:755:22: error: variable 'chars' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
Error compiling.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Old 03-31-2015, 12:19 AM   #3 (permalink)
Managed to figure it out. Never mind.
Old 03-31-2015, 12:53 PM   #4 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
So what was the answer?
Old 03-31-2015, 05:36 PM   #5 (permalink)
I was using too new of a version of the Arduino software. I downgraded to an older one and things loaded right up.
The Following 2 Users Say Thank You to firehawk618 For This Useful Post:
MobilOne (11-20-2015), nemo (03-31-2015)
Old 11-20-2015, 04:07 AM   #6 (permalink)
which version
Which older version did you use and what version of the UNO do you have
The Following User Says Thank You to Yezok1 For This Useful Post:
