Old 09-06-2015, 11:29 PM   #1 (permalink)
MPGDuino with Common-Rail diesel?
Hi,
can you make the MPGDuino work with a CR diesel? The only problem should be that injector flow is a function of rail pressure and boost (and opening duration), so two more sensors to read.
Old 09-07-2015, 10:06 AM   #2 (permalink)
As long as it complies to the OBD-2, it works. And I never saw any common-rail engine that was not compliant to OBD-2...
Old 09-15-2015, 08:23 PM   #3 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 43.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 34.87 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 36.8 mpg (US)
From memory the answer is no, an MPGuino won't work on a CRD unless the ECU reports a separate fuel economy signal (as most European diesels do). If you can wire up a second Arduino to process the required inputs and output a suitable signal then yes
It has come up before so try a search, but I don't think anyone's actually done it the hard way.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
