"MPGiata" modding thread: aiming for 50 MPG with a 1990 Miata. Update: success, 55 MPG!
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1505756110
You may have already seen my initial Miata thread, which documents the saga of buying and repairing this fun old turd bucket to make it road legal. Time for a fresh thread that focuses on the ecomodding! The car:
MPG potential: EPA says: 22 city / 28 highway / 24 combined AntiochOG did a 50 mpg fill using pulse & glide (but P&G is not my plan): 50 mpg! (1990 Mazda Miata) The top 3 Miatas in EM's garage:
The goal: 50 MPG (US) / 4.7 L/100 km, in my typical summer driving environment:
Results so far: 1) 37.5 mpg US = 6.1 L/100 km: first fill last year, cool autumn driving (10-15 C = 50-60 F) with no mods other than tire pressure; |
Mods
Completed mods:
(in no particular order) - MPGuino fuel economy computer http://ecomodder.com/forum/attachmen...1&d=1504021128- 50 PSI - zero-toe alignment - cleaned & regapped spark plugs (the gap was 0.010 wider than spec!) - air conditioning delete (removed components) http://ecomodder.com/forum/attachmen...1&d=1505940906- power steering delete (belt removed) - ignition timing advance http://ecomodder.com/forum/attachmen...1&d=1508874437- air dam, with... - partial grille block http://ecomodder.com/forum/attachmen...1&d=1505756110- half size radiator, and... - one of two factory cooling fans deleted http://ecomodder.com/forum/attachmen...1&d=1492450727 http://ecomodder.com/forum/attachmen...1&d=1492450727- smooth wheel discs http://ecomodder.com/forum/attachmen...1&d=1505497330- taller gearing (larger diameter rear wheels/tires) http://ecomodder.com/forum/attachmen...1&d=1505309221- side mirrors delete/relocated inside - LRR tires on the front, narrower than stock: 165/64R14 Dunlop Enasave http://ecomodder.com/forum/attachmen...1&d=1506615796- wiper delete - synthetic motor oil: 66% 5w30 + 33% 10w30 - weight reduction (goal: 100 lbs / 45 kg is attainable) - MAF / open loop AFR adjustment http://ecomodder.com/forum/attachmen...1&d=1508874484- synthetic lighter weight transmission oil (50% lightweight GM Syncromesh + synth 75w90) - synthetic differential oil - WAI - warm air intake (More info & pics to come.) Future mods: - engine kill switch (been using the key) - coolant/block heater - reduce disc brake drag (springs are missing; service calipers) - rear fender skirts - fairing ahead of rear tires - fairing behind rear wheels http://ecomodder.com/forum/attachmen...1&d=1507497234 http://ecomodder.com/forum/attachmen...1&d=1507497398 http://ecomodder.com/forum/attachmen...1&d=1507497516- fairing behind front wheels - belly pan - decklid extension/spoiler? http://ecomodder.com/forum/attachmen...1&d=1507754694- weight reduction: power steering pump delete - lower it a bit? Dream mods (but probably not) - targa style aero bodywork aft of the seats - mini boat tail! - ??? |
(post reserved)
possible parts car
My mechanic says he's buying a 1990 Miata for its drivetrain (to swap into an MG). The body is shot (rust).
He asked me: "Need any parts?" What stuff would you grab from an ecomodding angle? Off the top of my head, I couldn't think of anything. What stuff should I grab purely to have spare parts on hand? --- Edit: I need a driver's side sun visor! |
He's keeping the water pump, but the radiator is a possibility. I already replaced mine, though.
Unfortunately, the rear end was the same for all of this generation. A taller diff would be fantastic. Plus it'd let me run the slightly smaller diameter & narrower LRR tires on the back too. |
You should also be able to adjust the idle speed on that NA miata. The bros NB miata is too new for that. AND we can't adjust the ignition advance! Enjoy the adjustability of your old miata! His NB miata idles at 900-1000 rpm.
That's an ambitious goal.
It needs to be aerodynamically perfect. The killer is the top down driving enjoyment. Maybe chop the windshield and add a metal tonneau cover and headrest fairing? That said, your list doesn't include a rear diverter. http://ecomodder.com/forum/member-fr...11-silver4.jpg For the rear wheel fairings, I like what I call the Bonnevette: http://ecomodder.com/forum/member-fr...bonnevette.jpg Starting just inside the tire they flair out to flush with the outer tire face at the back. Wheelwell turbulence is separated from the underbody flow and thrown outward into the ambient airstream. They would also form the outer fences of a diverter bell with a 4° angle roof. |
48!
Diverter bell!
--- 4th fill-up tonight: 48 MPG. :) [Correction! 49.9 mpg! -- see post #18] I would like to be able to cruise a little faster than I have been, though. Mods will continue! Average speed may (will probably) increase. And it looks like another week of warm weather coming, so the cold won't mess with my progress just yet. |
i hope u will set the mixture somewhat leaner, as i suggested in the the other thread. u will love it, i promise. miatas running verry rich in open loop. |
Metro, see if you can get your hands on a 4.1 rear diff from a 94-99 car, it will lower your RPM by like 5%. They can be had for cheap. You may he able to trade someone for free who wants your 4.3 for track use.
