Old 08-30-2009, 11:12 PM   #1 (permalink)
1991 Metro 1.0 Auto - '91 Metro Lsi Auto
90 day: 38.39 mpg (US)
MPGuino 1991 AUTOMATIC
I can't find anything about hooking this to an Auto trans car (1991 geo metro 1.0), I'm quite sure I have the pos, grnd and injector connections correct but the VSS is different than the manual cars. My car has a separate VSS in the transmission with 2 wires going to it I tried both of them and the first one didn't seem to do anything and the second one did once the speed was brought up (on jack stands for testing).
I know my speedometer is off due to the 13" tire/wheel upgrade (I calculated 8.3333% difference). I adjusted the VSS pulses per mile to 7524 from 8208 but now that I think about it this probably isn't right but I didn't want to start with a value that I know is wrong.
How much of an adjustment does this parameter take for a change like I have?
I didn't see (on the wiki or here) a way to get the MPGuino to display the VSS pulse count either or I could use that? if this is possible how is it done?
I get no instantaneous MPG reading until I get up to about 40MPH and then if I accelerate long enough the reading drops until it gets all the way down to zero and stays there until I lift completely off the accelerator-then it pops back up to 999- any ideas why it would do this? (I know 999 means coasting in gear already)
Old 08-30-2009, 11:24 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Dunno if this thread will help or not with the vss. But you want the one in the speedo, not the one from the trans I think (different signal strengths).
Finding the elusive VSS
^89 metro w/auto
The Following User Says Thank You to dcb For This Useful Post:
robertwb70 (08-31-2009)
Old 08-31-2009, 12:40 AM   #3 (permalink)
OK I found the yellow/green wire under the dash on the drivers side above the fuse block ( the ECU is right there too). That made everything work much better and I was able to get a rough speed calibration for my car of 8100 pulses ( I went 50 MPH on the speedo and tried to get MPGuino to indicate 54.16 for the 8.333% difference) close enough for now.
It did freeze up on me once and there is one part on the back that I noticed gets a little warm is this normal or might I still have some connection problem?
So, from here, if I understand this right, once I get actual mileage from the next tank I start adjusting the injector input until I can get actual and MPGuino mileage to match right?
Old 08-31-2009, 12:45 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
Here is the calibration page, it should spell it out, might want to be sure all connections are solid first and I would just leave it on the custom screen while driving to reduce the possibility of freeze in mid calibration.
Mpguino calibration - EcoModder
Old 08-31-2009, 12:54 AM   #5 (permalink)
Thanks, don't know how I missed that page with all the time I've been looking at stuff for this- that's just what I was looking for.
Old 08-31-2009, 01:04 AM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
good deal
Old 08-31-2009, 12:19 PM   #7 (permalink)
The unit was working good today but it froze about 5 miles from home.
What causes it to freeze and is there a way to stop it from happening?
What is the best course of action to get it working again without wiping out the memory?
There is a part (op-amp I think?) in the picture below that gets too hot to touch for more than 1 second- is this normal or a sign of a problem?
Old 08-31-2009, 12:26 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
that is the voltage regulator, it can get warm. I don't have a pat answer on the freezing, can you describe the conditions when it happened?
I would turn the brightness down (with the middle button) to like 1, and that should keep the regulator happier anyway.
Old 08-31-2009, 04:43 PM   #9 (permalink)
I keep the brightness set at one already.
Today it happened (I think) right after I hit a good size bump in the road in a construction zone (the 40 psi in the tires makes bumps feel a little worse than they really are).
So disconnect/ reconnect the power the only way to get it going again?
Old 09-20-2009, 01:57 AM   #10 (permalink)
I finally got around to the last resort yesterday - hooking the unit directly to the battery, and it looks like that has solved all the issues I was having. It has worked 2 days now and about 65 miles which is a new record for me.
It was so bad last week I just unplugged it for about 4 days because it would freeze and/or reset itself almost continuously...I was starting to think something was wrong with it.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
MPGuino rebooting and freezing also... Power issue? tygertec OpenGauge / MPGuino FE computer 28 04-17-2011 05:05 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Locking an automatic in a single gear? bennelson EcoModding Central 11 11-14-2008 02:03 PM
My MpGuino 1991 Metro Xfi bbjsw10 OpenGauge / MPGuino FE computer 9 11-04-2008 10:13 PM
