Old 11-16-2008, 04:39 PM   #1 (permalink)
Legacy GT - '98 Legacy GT
90 day: 21.05 mpg (US)
Bike - '07 CBR1000RR
Mpguino 98 subaru legacy
I just built and installed the mpguino on my subaru and i'm very impressed. Currently i am using a freeduino connected with an lcd but would like to get the mpguino from fundamental logic, i had some problems with emails when i first tried ordering and they are still currently out of stock atm. I think their board will be a much nicer package then my loose buttons lcd and freeduino.
The 4 connections for power ground vss and injector i made at the ecu on the passenger floor board. they were relatively easy, although i do have some experience installing remote starters and alarms, but i did get the wires right on the first try. The telephone wire messed me up, it's not a crossover type cable so on one connector everything works right and the other end it is all reversed.
I do have a few questions about the software. Is there any direct way to read mph or rpm to make initial set up easier? I understand how to find the correct reading but that takes a tank of gas? or measured amount of fuel?
Thanks
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1010 05-23-2012 07:23 AM
MPGuino installation/setup: 1998 Geo Metro (Pontiac Firefly) MetroMPG OpenGauge / MPGuino FE computer 12 10-11-2009 03:29 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 05:35 PM
iDuino MPGuino wyatt OpenGauge / MPGuino FE computer 146 02-20-2009 12:23 PM
Some suggestions and notes on the MPGuino SVOboy OpenGauge / MPGuino FE computer 4 08-01-2008 08:00 AM
