Old 12-17-2016, 01:40 PM   #1 (permalink)
VW GOLF - '96 Volkwagen Golf MK3 GL
90 day: 50.21 mpg (US)
Commute scoot - '95 Suzuki AE50 Style
Last 3: 70.4 mpg (US)
The German - '99 Mercedes W202 C200 Classic
90 day: 27.65 mpg (US)
MPGuino injector connection - no 0v feed
I've built my MPGuino and have got it recognising the difference between stopped (0mph) and moving (some mph).
I just want to double check the connection to the injector system. I have a 1999 Mercedes Benz C-Class (petrol). It uses a HFM or PMS injection system (Siemens I think, or maybe Bosch?).
I have probed the injector wires with a digi-meter in DV volts mode (20v), connected with (+) in the plug and (-) tgoing to a bolt on the head, looking for the 0v one.
I can see there is one hovering just under (12v) which must be the power wire, but the other starts at 0v then rises quickly to around 5v.
Now I assume "injectors is injectors" so to speak, and the 5v wire is the one to tap into. Surely the Bosch fuel system on the car cannot be any different from any other injection system?
Anyone got a clue (coz I don't!)...
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
Old 12-18-2016, 01:59 PM   #2 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
It would seem that you found the injector wire to use. Go ahead and try to use the wire that starts off at 0 VDC, then rises to about 5 VDC. That is likely your DVM charging up the capacitor filter on the injector switching circuit.
Old 12-18-2016, 02:42 PM   #3 (permalink)
Cheers - I can confirm that's the correct wire - the car isn't bothered by the connection and the MPGuino now shows some numbers from the injector.
Hopefully will get the vss problem sorted and be in business after some calibration.
