Old 06-03-2009, 07:49 PM   #21 (permalink)
EcoModding Punk
LeanBurninating's Avatar
Honduh Power - '98 Civic HX
90 day: 44.37 mpg (US)
Thank you for the help.
Almost done dialing it in.
Right now my calibration values are:
VSS pulse / mile
8208
Microsec / Gallon
287696156
And with those I think it is reasonably accurate. Time will tell. For reference, my car is currently running 185/60/14s instead of the factory sized 185/65/14s.
Thank you for bearing with me on all my dumb questions, hopefully you will find this one slightly more intelligent:
My current values for "injector delay us" is 500, for "Inj Trg 0-Dn 1-up" is 0, and for "VSS delay ms" is 2.
Are these values having any effect?
The Following User Says Thank You to LeanBurninating For This Useful Post:
jorymil (09-25-2011)
Old 06-03-2009, 07:51 PM   #22 (permalink)
EcoModding Punk
I also forgot.. about cooling. My options are putting the guino in a white box, and moving the whole thing out of direct sunlight. I don't plan on doing either of those.
I will drill more holes, but other than that any ideas?
Thanks again.
Old 06-02-2010, 04:40 PM   #23 (permalink)
HX1 - '98 Civic HX
90 day: 48.08 mpg (US)
PriusG2 - '09 Prius II
90 day: 47.91 mpg (US)
PriusG2-MFD - '09 Prius II
90 day: 50.3 mpg (US)
I wanted to post a follow up even though this was not my thread. I used the white wire from the fuse box for 12 volts like the original poster and I suffered from a lot of resets. I have now changed to a fused wire directly from the battery and no longer have any resets for several tanks of gas with MPGuino. Just in case any one else tries using the white wire from the fuse box, it appears to be too noisy for MPGuino.
Prius MFD fuel Log
Prius Gallons at fill up Log
Old 06-05-2010, 05:48 PM   #24 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.96 mpg (US)
About setting VSS pulses -
When you can, borrow a GPS from a friend and calibrate the Guino to that. Drive it for a few hundred miles if you can borrow it for that long. I did that in preparation for the Green Grand Prix rally and it was an eye opener. With stock size tires (185/65-14) I need to multiply odo readings by 1.009xx to get GPS readings.
Also get a correction factor so you can get GPS/Guino miles from your trip odometer. That one has saved my backside a couple times already, when the Guino had a reset for one reason or another.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Old 06-14-2010, 07:55 AM   #25 (permalink)
Undecided - '96 Civic HX
Last 3: 38.01 mpg (US)
Great thread, I will be bookmarking and referencing soon. Thank you to all the HX owners and other members who have responded.
Old 06-14-2010, 10:04 AM   #26 (permalink)
Originally Posted by LeanBurninating View Post
I am pretty pleased with how it all turned out, except for the wire insulator deal I used... it looks better than four naked wires but it still looks like it belongs on a robot. haha. Any ideas on how I can cover up those wires more discreetly?
How did you ever get it to fit so nicely into that box? There is like zero gap between the screen and the box. I just put mine together yesterday and it looks like crap compared to yours. Maybe my dremmel skills aren't like yours. :P
Old 07-14-2010, 10:49 AM   #27 (permalink)
1999 Honda Civic HX 5MT
LinuxGold's Avatar
LeanBurninating -- do you still have pictures of your MPGuino wiring? I got my 1999 Honda Civic HX and am looking for ideas on where to put MPGuino and to wire them.
Thanks.
Old 10-16-2010, 03:02 PM   #28 (permalink)
Thanks for the link to the pin connector. It is a life saver.
Old 10-29-2010, 02:40 PM   #29 (permalink)
EG6 - '93 Civic Si
Nice install and very helpful. Saving funds for an MPGuino now.
Old 03-14-2011, 02:19 PM   #30 (permalink)
4mula's Avatar
The Egg-Mobile - '94 Civic VX
90 day: 44.88 mpg (US)
I'm also wondering how you got such an awesome fit in the enclosure, did you you a dremel?
Chance to replace my Civic EX with a Civic HX ZachUA General Efficiency Discussion 12 05-10-2009 11:24 AM
Wanted: Civic HX 4 replacement or Civic shell needing an engine HDCaptain For Sale 1 03-14-2009 02:57 PM
EcoMod Lurker needing help with wrecked Civic HX HDCaptain Introductions 7 12-08-2008 07:55 AM
96 Civic DX HB vs civic HX EngineeredCivic EcoModding Central 4 09-21-2008 08:30 PM
Civic HX or DX GregM EcoModding Central 7 07-22-2008 10:27 AM
