Old 12-13-2009, 11:10 PM   #1 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
MPGuino issues
I just got done installing my MPGuino in the wife's 1997 Metro. I got a constant power source, a solid ground, tapped into the ECU for the vss and the injector wire. It booted up and I went through the setup. As soon as I started driving, the MPGuino began flashing rapidly until I get above 40 MPH and then goes blank. When I reduce speed it comes back on, but flashing rapidly (like vss or inj signal flashes) and when I come to a stop is stops flashing and reboots?
Old 12-14-2009, 12:04 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I think some wires must be crossed, I know that plug is frustratingly small. It tested ok on the bench, not too likely it got messed up in that maner in transit.
can you trace your taps to the labled connectors (batt, gnd, inj,vss)
It might need a reflash if it was being powered from the vss on accident),
note: you can lift the plastic tang on the plug gently with an exacto knife and slide the pin socket out if you want to try it with the vss disconnected or need to shuffle pins around.
Do you know if you got a gph reading before you started driving (GH)?
Old 12-14-2009, 12:09 AM   #3 (permalink)
Hi-Tech Redneck
I will double check the wires tomorrow. When first boot happened, it did have a gh reading.
Old 12-14-2009, 01:49 AM   #4 (permalink)
Draco - '89 F150 ext cab shrt bed XLT Lariat
90 day: 16.45 mpg (US)
Mine did that on the first run. went straight to the batt for power and better solder job cleared it up.
Where can I get a new plug? or just new terminals My solder skills were a bit rusty, I checked radio shack but no luck.
Because we are big dumb redneck Americans and we only want V8s that thunder and use lots of gas pushing our empty Super Duties down the highway at 100 MPH in the fast lane while warming our butts in heated leather seats and chowing down on double quarter pounders and texting on our cell phones. We cant understand non-V8 engines because that ain't whut NASCAR uses...
Not this American.
Old 12-14-2009, 08:12 AM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
It is the same plug is used to power a 3.5" floppy. If you have a desktop computer you probably have a spare inside there that you can cut out with a bit of pigtail. (turn off power first)
The Following 2 Users Say Thank You to dcb For This Useful Post:
CoastRider (12-16-2009), Johnny Mullet (12-14-2009)
Old 12-14-2009, 11:41 AM   #6 (permalink)
Hi-Tech Redneck
I just went into the closet and stripped the plug from my old eMachines eTower 667
Much easier this time around to wire it in. Can't wait for the wife to get home so I can finish it. I will update.
Old 12-15-2009, 09:22 PM   #7 (permalink)
Hi-Tech Redneck
Well, I finally got around to finishing the MPGuino project. I had a few wires backwards making the initial problems I had. This must be a well built device since I had the positive switched with the Injector pulse making the thing flash with great intensity. I brought Blue Jay into Mullet's Redneck Repair Shop.............
Using the instructions found HERE I tapped into the fuel injector first..........
And then to the VSS wire at the ECU here........
I took it for a nice ride, but it was snowing and we had a couple inches on the ground, so I could not get the full experiment out of it, but it works well! I may just have to get one installed in my Metro now.
Just a tip. If you sell these with a pre-made plug with a foot of wire for each terminal, this would take a lot of frustration out of installing it.
Old 12-15-2009, 10:10 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
Hey thats good news, glad it survived Yah the plug kit is a pita, I'm reviewing the options there.
FYI, I had it in the center of the panel so it didn't block the oil or SES lights.
Old 12-16-2009, 02:14 AM   #9 (permalink)
Good idea! I think an pigtail plug woulda been sweet!
Not this American.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1010 05-23-2012 07:23 AM
MPGuino rebooting and freezing also... Power issue? tygertec OpenGauge / MPGuino FE computer 28 04-17-2011 04:05 PM
Mpguino Rebooting and Freezing but... mkiitmr2 OpenGauge / MPGuino FE computer 10 01-22-2011 04:28 AM
All default values for MPGuino? JohnNeiferd OpenGauge / MPGuino FE computer 2 09-16-2009 12:24 PM
MpGuino compatibilty issues bbjsw10 OpenGauge / MPGuino FE computer 21 09-28-2008 03:32 PM
