Old 10-13-2008, 09:16 PM   #21 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
I had another idea while sitting here trying to figure out WTH is going on. What about adding a couple diodes to the signal wires? Maybe the problem isn't a surge in but a surge out. When I am turning car killing engine maybe the injector or vss is looking for a ground and the Guino is there to provide it for it. Just add a couple where I have the arrows to. dcb hope you don't mind me using your schematic image.
Old 10-13-2008, 11:00 PM   #22 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I don't mean to bridge threads, but I was concerned about a cold solder when you said the vss stopped working.
Do you think maybe you could plug it in on the desktop and poke around a bit with a wooden skewer on all the leads/connections and see if anything reacts badly to poking?
Old 10-14-2008, 11:59 AM   #23 (permalink)
ptsmith24's Avatar
El Camrino - '90 Camry LE
90 day: 32.47 mpg (US)
Mine hasn't frozen up in ~400 miles... though it's been cooler, I'm headed back south (relative, lol) and it'll be in the 90s again....at least for a few days. Maybe it's finished acting up, who knows?
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Old 10-14-2008, 11:02 PM   #24 (permalink)
Addicted
bbjsw10's Avatar
Well I am officially un-soldering everything and starting over. This time I am using schematic for pcb style. I will use my Iduino board to program then pop into pcb board. I have too many jumper wires on my current shield setup and causing alot of problems troubleshooting this. I will report back in a few days. Thanks for the help guys. I need a restart from scratch, maybe that will solve it.
Old 10-16-2008, 08:24 AM   #25 (permalink)
Addicted
bbjsw10's Avatar
I completed my scratch built using dcb's schematic. Test drove last night and seemed to work a lot smoother the instant speed was not as bouncy. I am guessing my old board was just not right somewhere. Time will tell if I have any problems. I don't ever remember the other one running this smooth on readings though, this one is smooth as butter on readings no more jumpy readings. Wish me luck.
Old 10-16-2008, 08:51 AM   #26 (permalink)
dcb
needs more cowbell
dcb's Avatar
That is a very encouraging report
Old 10-16-2008, 06:24 PM   #27 (permalink)
Addicted
bbjsw10's Avatar
So far no resets or lockups, except when I tried to reset tank while moving. I imagine you shouldn't do that though. So far the rebuild is the best thing I could have done. Will test more tonight though.
Old 10-17-2008, 12:11 AM   #28 (permalink)
Addicted
bbjsw10's Avatar
I drove 27 miles tonight 20 in the country and 7 in town with P&G and no Resets so far. And 8208 on VSS seems pretty dang close. I recommend to anyone having problems with this to just either buy the kit or build the pcb version and use the schematic in that thread. It cuts out alot of the extra connections that can cause a problem.
Old 10-18-2008, 06:20 PM   #29 (permalink)
Addicted
bbjsw10's Avatar
Well I had a lock up yesterday night and brought it home opened the case, and Voila!! My left switch connector had made contact with the board. So I broke out the hot glue gun and covered all of the backside of the board and switch connections, problem solved.
Hot glue your Guino's please save yourself a headache later.
Old 10-18-2008, 06:25 PM   #30 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
MPGuino installation/setup: 1998 Geo Metro (Pontiac Firefly) MetroMPG OpenGauge / MPGuino FE computer 12 10-11-2009 04:29 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
Restricted fuel system affect mpguino readings? wagonman76 OpenGauge / MPGuino FE computer 1 09-09-2008 02:34 PM
Some suggestions and notes on the MPGuino SVOboy OpenGauge / MPGuino FE computer 4 08-01-2008 09:00 AM
