Old 08-13-2010, 11:17 AM   #11 (permalink)
As you outputting data to a Lap Top, way not display it on the Laptop screen??
That can be big enough and in most condutions bright enough.
Can that be done alond with data logging?
Rich
Old 08-15-2010, 09:20 AM   #12 (permalink)
'91 CRX - '91 CRX DX
90 day: 34.91 mpg (US)
Many laptop screens have optical issues for automotive applications. As your viewing angle goes off-axis, the contrast ratio suffers, which means too much light being thrown at the user. Take a laptop in a dark room and set it to display as dark an image as is reasonable (a black picture, don't mess with the display brightness settings and such). Turn the laptop around so the screen is facing away from you and use it like a flashlight. Point it at a white wall and you will see patches of light and dark - soft beams of light coming off the laptop display at various angles. This is light the display cannot control... Light that will be given off no matter what's being displayed on the screen.
You're probably thinking "okay, that's kind of interesting but why does it matter?" The answer: Night driving. Those stray beams of light coming off the display will light up your car interior at night, making the road more difficult to see.
Really, the simplified LCDs used by the MPGuino have the same issue, but the screens are far smaller and backlight brightness far lower than a laptop, resulting in far less stray light.
Old 08-15-2010, 10:08 AM   #13 (permalink)
I drive a lot running a laptop, montoring AFR, TPS, EGT, and GPS, and have not had a problem with 90% of what you say, once in a while sunlight can wash out the screen.
I for one would really like a laptop display program.
Rich
Old 09-22-2010, 12:57 PM   #14 (permalink)
cmj
Honda - '96 Civic EX
90 day: 36.12 mpg (US)
A simple processing script could easily display the incoming serial information any way you wish. You could even go further and create pretty gauges and warning lights with very little effort.
Is there still a need for the push buttons if you run this headless? Does it send all the information via serial at the same time?
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1010 05-23-2012 07:23 AM
MPGuino installation/setup: 1998 Geo Metro (Pontiac Firefly) MetroMPG OpenGauge / MPGuino FE computer 12 10-11-2009 03:29 PM
iDuino MPGuino wyatt OpenGauge / MPGuino FE computer 146 02-20-2009 12:23 PM
Mpguino acting weird forgottenmindset OpenGauge / MPGuino FE computer 2 08-23-2008 10:07 AM
Some suggestions and notes on the MPGuino SVOboy OpenGauge / MPGuino FE computer 4 08-01-2008 08:00 AM
