Old 04-01-2015, 12:38 AM   #11 (permalink)
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
Thanks, the next time I take it apart I will switch out transistor types.
Maybe the schematic should be updated on the wiki?
1998 LX with a full HX swap + VX transaxle.
Old 04-01-2015, 03:17 AM   #12 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Not a bad idea
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 04-01-2015, 03:26 PM   #13 (permalink)
Or is the transistor issue the fact that maybe we are using different LCD displays?
I just had one laying around so I used it.
Old 04-02-2015, 03:00 AM   #14 (permalink)
AndrzejM's Avatar
That's because PNP transistor requires different signal than NPN - NPN with zero signal on the base will cut the current and PNP will cut the current with the high setting. That's why LCD was not dimmed but was brightened to the max. To make it work with a PNP transistor you would need to change the code to dimm LCD with the "high" voltage.
The Following User Says Thank You to AndrzejM For This Useful Post:
firehawk618 (04-02-2015)
Old 04-02-2015, 12:19 PM   #15 (permalink)
Thanks for the input. I will try modifying the code before modifying the hardware.
Old 04-02-2015, 10:52 PM   #16 (permalink)
AndrezejM, thanks! I was able to edit 2 lines in the code.
My brightness now works as it should instead of backwards.
I will report back if the light now turns off after a timeout period.
Old 04-07-2015, 03:30 AM   #17 (permalink)
AndrzejM's Avatar
Which version of the code have you modified? There's at least 4 versions of that...
Old 04-07-2015, 07:50 PM   #18 (permalink)
I am not entirely sure.
I will attach it here if you feel so inclined to look at it and fix my dumb dumb editing!
Old 04-08-2015, 05:02 AM   #19 (permalink)
AndrzejM's Avatar
That's a very old version of the code. I'd recommend using code described here: http://ecomodder.com/forum/showthrea...tml#post381830
Old 04-08-2015, 12:32 PM   #20 (permalink)
Thanks for the information. I will check that out!
On a side note, the pre-assembled mpguino I purchased on 3/4/15 is FINALLY scheduled for delivery today. That's the one I will be running.
The one I assembled was mainly to play with it and get some experience dialing it in.
Hopefully the vss fine tuning I have done will apply to the pre-assembled unit!
