Old 04-08-2015, 12:36 PM   #21 (permalink)
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
Thanks for the information. I will check that out!
On a side note, the pre-assembled mpguino I purchased on 3/4/15 is FINALLY scheduled for delivery today. That's the one I will be running.
The one I assembled was mainly to play with it and get some experience dialing it in.
Hopefully the vss fine tuning I have done will apply to the pre-assembled unit!
1998 LX with a full HX swap + VX transaxle.
Old 04-09-2015, 12:15 AM   #22 (permalink)
AndrzejM, thanks for all your help.
I have abandoned my MPGuino that I put together from the Arduino UNO.
The pre-assembled one I ordered a month ago showed up.
I will say that whatever program he loaded on it is 100x nicer than the old version I was running.
This one seems like it's going to be a lot closer to real numbers vs the old one.
The one I bought was from the link below in case anyone else is interested.
Be warned, shipping is the better part of a MONTH from his country to the Seattle area.
I will also advise, when you look at the included harness do NOT assume that red / black is power. You must look at the circuit board to determine where the wires go. It turned out that white / yellow were the ones that needed power. I simply removed the pins from the connector and re-arranged them so that red/black were power.
MPGuino trip computer - MPGuino
