Old 12-05-2008, 12:19 AM   #41 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
Originally Posted by i_am_socket View Post
Too bad the kit doesn't come with wire taps. Hopefully off to Rat Shack this weekend...
Question though... am I looking for this or this?
I would do this will go much farther than those $2 taps, could ever think of. Just my .02
Old 12-05-2008, 06:39 AM   #42 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
what bbj said I tried the clips, they are really cheesey. I just carefully cut away a bit of the insulation where you want to tap the signal/power/ground, solder up the lead, cover the junction it in silicon/hot glue/paint/bacon grease/whatever to keep it from oxidizing.
Old 12-05-2008, 10:28 AM   #43 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
Yes, I could certainly go that route too, but I have a terrible time stripping the middle of a wire. Ah, well. Better to do it the right way than "close enough" with electronics inside expensive machinery that I'm trusting my life in.
Thanks guys
Old 12-05-2008, 10:40 AM   #44 (permalink)
The Crimson Crawler - '04 Elantra GLS
90 day: 36.71 mpg (US)
A tip if you want to solder:
Find nail clippers. They work GREAT for making minute snips in insulation without nicking the wires.
Also, if instead of using the side of the clippers to clip with, you place the front of the clippers flat against the insulation, you can use them to "gnaw" a starter patch open.
Old 12-06-2008, 03:15 PM   #45 (permalink)
Wingmn's Avatar
93 SL2 Auto - '93 SL2
90 day: 34.55 mpg (US)
09 Outlook FWD - '09 Outlook XR
90 day: 21.07 mpg (US)
Hey guys, I ordered a Ver 2 kit, and I've got some things I'm concerned about... I have a 93 Saturn SL2 (Auto) and I have a Haynes Manual which is where I'm looking at the wiring diagrams to figure out where I'm going to tap in my wires.
It looks like I have a VSS Hi and VSS Lo wire. Also, there are wires for each individual fuel injector..
Which wires will I use? The 12 V and the ground are a no brainer, but the VSS hi and VSS lo, and does it matter which injector I tap into? Those are my concerns, these are all wires going into the PCM. Is that the same as the ECU that I've read about? I'm assuming it is, but I just thought I'd ask.
I've only seen a 1997 Saturn as far as reference numbers for hooking up the MPGuino, so if anyone has any tips for me I would REALLY appreciate it. Thanks!
Old 12-06-2008, 03:34 PM   #46 (permalink)
dcb
needs more cowbell
dcb's Avatar
Do you see a "speed" signal anywhere? should be coming out of the ecu going to the speedometer cluster.
Old 12-06-2008, 04:10 PM   #47 (permalink)
Wingmn's Avatar
Yes, I do see a a pin labeled speed out
Old 12-06-2008, 04:51 PM   #48 (permalink)
dcb
needs more cowbell
dcb's Avatar
That's the one you want
Old 12-06-2008, 05:54 PM   #49 (permalink)
Wingmn's Avatar
Any suggestions on the Injector wire? Does it matter which one I tap in to? 1,2,3,4?
Old 12-06-2008, 07:06 PM   #50 (permalink)
dcb
needs more cowbell
dcb's Avatar
any injector will work, it's just a question of which wire (of two possible wires). If you unplug the injectors and turn on the ignition (not start), you can probe an injector harness plug, you want the lead that doesn't have 12 volts on it when measured to ground.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
iDuino MPGuino wyatt OpenGauge / MPGuino FE computer 146 02-20-2009 01:23 PM
DIY - Front Camber Kit SVOboy DIY / How-to 1 12-05-2008 01:52 PM
Sterling Kit Car cfg83 Aerodynamics 12 01-16-2008 09:33 PM
