Old 12-29-2008, 02:58 PM   #61 (permalink)
Wingmn's Avatar
93 SL2 Auto - '93 SL2
90 day: 34.26 mpg (US)
09 Outlook FWD - '09 Outlook XR
90 day: 21.07 mpg (US)
Well, I went and picked up a new 7805 from Radioshack, I'll have to wait until either tonight or New Years day before I get to desolder my LCD board to get to the 7805 to change it out... I'll post results when I'm done...
Thanks for the inputs.
Old 12-30-2008, 02:28 AM   #62 (permalink)
Wingmn's Avatar
Well, I guess I got anxious - so I went ahead and desoldered after work this morning - desoldering that LCD from the other board is a bit of a pain...
I got the 7805 off - ohm checked it again to verify my results and they were the same - I ohmed checked the new 7805 and some of the measurements were identical - so I was concerned... But there were 2 measurements that were not the same, so I figured I'd try it anyway..
Soldered everything back together (also touched up 2 questionable solder joints)- hooked it up to PC power again to make sure I didn't really screw anything up and it still worked like before
So, the real test was plugging it into the car (I had left my temp power and ground cable soldered in). So, after waiting a few mins between power off and on - I plugged it in.
And the LCD came on - and the Ver. came up and it worked!
So - the easy part is done. Now all I have to do is hook up the VSS and the INJ, and make my power and Ground a more permanent set up. I should hopefully have it done by the end of the week. Thanks again for the inputs.
Old 12-31-2008, 06:22 PM   #63 (permalink)
Wingmn's Avatar
Cables installed and routed and concealed.
I made an enclosure out of an Old Spice Deoderant stick (the semi clear one) thanks to some ideas I saw on another thread
I tested it out today (20 miles).
I used the settings dcb put up for his 97 Saturn info -
It seemed to work really well with all the BIG displays, but it froze on me when I used the small displays... So a total of 2 freezes...
I'll read up on the freeze fix, my Guino has Ver .73 on it.
Old 01-09-2009, 08:42 PM   #64 (permalink)
Tracy - '00 corsa
i managed to f^^k up my spitfire kit by over heating the board near the ready soldered surface mount chip.
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 04-30-2009, 07:15 PM   #65 (permalink)
doviatt's Avatar
Grey Goose - '89 Metro LSI 4 door hatch back
90 day: 59.36 mpg (US)
I have ordered me a MPGuino kit .....well....backordered duoh!!!
Oh well, I have something to look forward to.
I'll have plenty of time to read, research and avoid build and install issues.
Thank you all for blazing the path to success (especially dcb)!
Old 07-05-2011, 02:52 AM   #66 (permalink)
slave to the grind
TOOQIKK's Avatar
Sippy The Slow Sentra - '94 SENTRA EX
90 day: 45.73 mpg (US)
Send a message via AIM to TOOQIKK
are these still for sale???
Old 07-05-2011, 12:30 PM   #67 (permalink)
Suzi - '94 Swift GA
90 day: 48.94 mpg (US)
Prius II - '05 Prius Package 6
90 day: 46.51 mpg (US)
As far as I know. If it turns out they aren't, I have one that I would sell you. PM me if interested.
The Following User Says Thank You to wyatt For This Useful Post:
TOOQIKK (08-22-2011)
Old 08-21-2011, 10:16 PM   #68 (permalink)
I too am rather curious whether they are still being made...
Old 08-22-2011, 08:24 PM   #69 (permalink)
slave to the grind
TOOQIKK's Avatar
Thumbs up
got it today!
gotta say i was like what the .... when i first saw the phone jacks in the box lol
Old 08-22-2011, 10:11 PM   #70 (permalink)
Nice to know you got it! Let's hope I will get mine soon!
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1010 05-23-2012 07:23 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 05:35 PM
iDuino MPGuino wyatt OpenGauge / MPGuino FE computer 146 02-20-2009 12:23 PM
DIY - Front Camber Kit SVOboy DIY / How-to 1 12-05-2008 12:52 PM
Sterling Kit Car cfg83 Aerodynamics 12 01-16-2008 08:33 PM
