mpguino problem
Hi Im having a problem with my new mpguino, i hope someone can kindly give me some ideas.
The instant mpg stays generally the same regardless of throttle and rpm. It does though about every 5 seconds jump to a different figure for a fraction of a second before returning to its more rigid value. I haven't calibrated it yet but i think that shouldn't matter. Any tips? thanks |
Solved
Despite my care i had tapped the wrong wire for injector feed to mpguino. Injectors wires are hard to find because they operate as an earth signal and so basically impossible to ohm them! I ended up tapping injector wire right near injector :-P so I couldn't get it wrong. So good to have working calibarated fe gauge!! |
