Old 10-12-2017, 07:50 AM   #1 (permalink)
D15r's Avatar
Civr - '95 Honda Civic Ri
tinkerbell - '90 Honda integra xsi
smokey - '00 honda civic gli
90 day: 50.44 mpg (US)
mpguino problem
Hi Im having a problem with my new mpguino, i hope someone can kindly give me some ideas.
The instant mpg stays generally the same regardless of throttle and rpm. It does though about every 5 seconds jump to a different figure for a fraction of a second before returning to its more rigid value.
I haven't calibrated it yet but i think that shouldn't matter.
Any tips?
thanks
Old 10-13-2017, 05:35 AM   #2 (permalink)
D15r's Avatar
Solved
Despite my care i had tapped the wrong wire for injector feed to mpguino.
Injectors wires are hard to find because they operate as an earth signal and so basically impossible to ohm them!
I ended up tapping injector wire right near injector :-P so I couldn't get it wrong.
So good to have working calibarated fe gauge!!
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
