Old 07-01-2008, 05:13 PM   #391 (permalink)
awillard69's Avatar
Dakota - '00 Dakota Club Cab, Sport
90 day: 18.57 mpg (US)
Jeep - '01 Wrangler TJ Sport
90 day: 18.46 mpg (US)
Here's a tip, scavenge those switches from old VCR's or similar devices. You may find a few other items of interest as well.
Old 07-01-2008, 05:29 PM   #392 (permalink)
Wonderboy's Avatar
98 Civic - '98 Civic EX
90 day: 42.62 mpg (US)
CRXFi - '88 CRX HF / XFi
90 day: 38.84 mpg (US)
01 Insight - '01 Insight
90 day: 48.58 mpg (US)
So the wires that go into my injectors ARE actually colored differently upon closer inspection (red stripe on black & orange stripe on black). I chose the orange one, but I can't even tell if it is the correct one because I can't seem to get the LCD working.
The backlight is on, and it gets dimmer when I push any of the buttons, then it gets brighter when I release the button. Wrong switches maybe?
Old 07-01-2008, 06:08 PM   #393 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
WB, if your guino came up on the desktop but not by the vehicle, I suggest starting with reprogramming the guino. You have to be very deliberate about hooking up the power, flashing the power on and off can give it a case of amnesia. In severe cases you have to reload the bootloader (no fun). I probably need to add that caution to post 1. It should definately not get appreciably dimmer when pressing any button.
Old 07-01-2008, 06:44 PM   #394 (permalink)
Wonderboy,
Found this for you, it should help tons.
RapidShare: Easy Filehosting
You should be able to use any non full black wire from any of the injector leads.
The VSS seems to be the red/yellow one as you have correctly found.
Old 07-01-2008, 07:51 PM   #395 (permalink)
Wonderboy's Avatar
Whoa, that's a big find right there. I don't think I need it anymore, but that should be sticky for any toyota driver wanting to install a guino.
My problem remains as I retire this project for the evening:
I rechecked the wiring, and resoldered a couple ground connections, but the display is still flickery at times, but stays solid if you don't touch anything, and I reconfigured the buttons the other way... I still don't quite know how tactile switches are configured, nor do I know if my switches are normally on/off. This was never specified in the plans, and i'm not sure if it even matters. I only have 2 leads from each of the switches in the circuit, and the circuit goes across the switch on a side where the pins are visible:
Old 07-01-2008, 08:16 PM   #396 (permalink)
dcb
needs more cowbell
dcb's Avatar
Yah, Ruhass doesn't say much, but when he does it is usually pretty good. I have to figure out how to view a RAR file and take a look
The buttons are Normally open, one lead of each button should go to ground, the other leads to analog 3,4, and 5, one pin per button. What are you using for an arduino?
Old 07-01-2008, 11:14 PM   #397 (permalink)
dcb
needs more cowbell
dcb's Avatar
Initial scoping
Scope showed up today, it is a cute little portable 15mhz job
I scoped the power downstream of the 7805 and did not see anything, zoomed into max frequency and minimum voltage. It was rock solid, even while hitting switches and the blower and the starter, running or not, and tried the horn, nothing phazed it.
I scoped the injector, typical injector signal. I scoped pins 2/3 and they appeared well protected at the max resolution of the scope. The only issue I saw was the low end of the signal, and this may mean a hardware change is still needed. This is basically what I saw when zoomed in a bit on the pulse:
So the theory is that the mosfets (or whatever switches ground) drop the voltage to just about zero initially, but then the injector (being a large inductor) starts letting more current through, and the voltage rises to something approaching a volt. We *might* need to condition the signal a bit more to ensure we are solidly in LOW mode on those pins. Need to research it a bit more first.
I will have to wait till I fix the batteries on the scope to do anything interesting with VSS, this is a pretty cool tool though
Old 07-02-2008, 12:02 AM   #398 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Having button issues. The middle button (on a4) works fine and I can scroll left through the contrast screen on .66, however the left and right don't work. Both register 0 resistance from the iduino pin to ground while the middle one registers 1. Know what's up with this?
Old 07-02-2008, 12:26 AM   #399 (permalink)
dcb
needs more cowbell
dcb's Avatar
your middle button should be cycling through the numbers, left and right should be scrolling left and right. Can you double check the wiring and pin assignments?
Sounds like the LCD is working though
Old 07-02-2008, 12:58 AM   #400 (permalink)
Dartmouth 2010
SVOboy's Avatar
Yeah, troubleshooting for an hour has me here: Tapping the grounds from the left and right buttons against the pins on the iduino perform the appropriate function, but the buttons seem to be always closed. Is it possible they're just no good? Could they have been damaged in soldering?
My kingdom for a giant, heated workspace MetroMPG The Lounge 14 12-12-2010 10:08 AM
Motorcycle manufacturers beginning to release MPG info MetroMPG Motorcycles / Scooters 1 04-03-2008 06:23 PM
