Old 05-13-2008, 10:48 PM   #51 (permalink)
grnsat - '95 SL1
metro - '95 Metro LSi
I also noticed this in the code, the subtraction went the wrong direction..
Code:
void Trip::update(Trip t){
  seconds++;  //we call update once a second
  injPulses+=t.injPulses;
  vssPulses+=t.vssPulses;
  injHius+=t.injHius;
  if (injHius>=1000000){  //rollover into the injHiSec counter
    injHiSec++;
    //injHius=1000000-injHius; // **this would result in a negative number
    injHius-=1000000;  //  **correct
I'd considered using one of the inputs for the MAP signal, and also TPS. As for the fuel pressure changing.. I'm hoping to find more info on the factory FPRs.
Old 05-13-2008, 11:19 PM   #52 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
'preciate the logic catch Code updated.
Old 05-14-2008, 12:57 AM   #53 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
I'm having a problem with the Arduino IDE. I'm using "Arduino 11" for Mac OSX.
When I copy and paste the code, then I hit verify and it says
"19: error: Invalid suffix "b0010" on integer constant"
That's on the
"LcdCommandWrite(0b0010); // 4 bit operation"
line.
Anyone else having this problem?
PS - I tried copying and pasting several times, and even deleting the line and re-typing it, all to no avail.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 05-14-2008, 09:37 AM   #54 (permalink)
dcb
needs more cowbell
dcb's Avatar
I found it: a google on "invalid suffix on integer constant" produced:
http://forums.ladyada.net/viewtopic....edea840d313365
"instead of 0b100000 notation, use B100000 notation "
Code updated with the workaround.
Old 05-15-2008, 03:52 AM   #55 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Wow, really great work and progress
I know I said I'd be jumping in on this project over the summer.... But it doesn't look like that's even possible, given that I don't have a car at the moment
Challenge me, or correct me, but don't ask me to die quietly.
Old 05-15-2008, 06:28 PM   #56 (permalink)
grnsat - '95 SL1
parts list:
1 2n3906 NPN Transistor
needs to be PNP, unless you mean the 2n3904 you were talking about switching to. my board arrived today, so hoping to get testing soon..
Old 05-15-2008, 06:38 PM   #57 (permalink)
dcb
needs more cowbell
dcb's Avatar
oops, thx, yah, couldn't get enough gain out of the 2n3904 I had without blowing the pwm pin so stuck with the 2n3906. Updated.
Old 05-15-2008, 08:11 PM   #58 (permalink)
FuelSipper
HondaHokie - '95 Accord DX 4 door
90 day: 26.91 mpg (US)
dcb, one problem you might have been having with your vss and injector connection is the splicers you used. I got my splicers from Radioshack and I used the 20 to 22 gauge variety (red). The blue ones you have are for a thicker gauge of (15-18?). You might have been getting a weak connection because of the larger spacing.
Old 05-15-2008, 08:29 PM   #59 (permalink)
dcb
needs more cowbell
dcb's Avatar
Ah, cool. I went ahead and soldered my vss connection like the injection connection, then blobbed some blue rtv in/around the solder joint. I also started with the wrong wire, shoulda used Speedometer output instead of the vss
The thing is, the saturn doesn't have a speedometer cable, it has a hall effect thingie that sends the driveshaft rotation signal to the ecu, I was tapped into that (wrong). The ecu then generates a pulsed signal to the speedo (right).
On other cars, it may be that the speedometer IS connected via a speedometer cable and has a little switch in it that sends the distance info to the ecu.
Old 05-15-2008, 11:26 PM   #60 (permalink)
FuelSipper
I think I might be getting close to somewhere. I rebuilt my vss/injector connection circuit with the zeners. I tried firing it up with the signal troubleshoot code. My %D fluctuated from 0 to 13. The C fluctuated between 0 and 0.1 but rarely. Nothing with VC. T showed .1 or .2 like it was counting up.
I'm guessing I'm getting an injector signal but not a VSS signal.
My kingdom for a giant, heated workspace MetroMPG The Lounge 14 12-12-2010 10:08 AM
Motorcycle manufacturers beginning to release MPG info MetroMPG Motorcycles / Scooters 1 04-03-2008 06:23 PM
