Old 08-02-2009, 04:57 PM   #1 (permalink)
MPGuino resistance between +5V, ground
My MPGuino screen has been flaky, so I started looking for things to check. I found this thread which had dcb explaining to check the resistances on the LCD. I noticed that my pins 1 and 2 were only 11k Ohms. Thinking it was a bad solder job on the pins, I tried to remove them (but ended up scraping the PCB connection between pin 2 of the header and the voltage regulator. With this LCD pin now separate, I still get 11k Ohms between pins 2 and 3 of the regulator (+5 volts and ground).
Can someone check theirs and tell me what may be wrong? Thanks
mpguino, resistance, troubleshooting
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 90 11-18-2009 01:49 AM
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 894 10-22-2009 10:07 PM
Online tool: shows aerodynamic drag, rolling resistance, power required & est. MPG MetroMPG Aerodynamics 47 06-23-2009 11:22 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 64 05-30-2009 01:17 AM
Calculating Rolling Resistance SVOboy EcoModding Central 0 11-18-2007 04:20 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
