Old 05-24-2015, 11:00 PM   #1 (permalink)
Betsy - '97 Honda Civic HX
Mpguino settings Civic Hx
First of all, Hello all. I am new to the ecomodder scene but so far have liked what I've seen here. Just signed up but have been lurking on here for quite some time now.
I obtained a stock '97 Civic Hx through trade about a year ago after a devastating engine fire fiasco on my '98 Eclipse GSX. Since then I have absolutely loved the MPG this car puts out as is. About low to mid 40s, especially after some much need maintenance(egr was a mess). I now see that my '03 Tiburon Gt (my other car),which only gets about 23mpg, has been bleeding me dry. Purchased a MPguino for the Hx from mpguino.wiseman.ee/eng not too long after getting the car but just got around to installing it about a week ago. I love this little thing. Almost turns it into a game while driving to see how fuel efficient you can be. I have a vague understanding of the calibration thanks to the wiki page and installation page on the sellers website. What I don't know is about the other settings for my specific vehicle such as delay/inj. type/ect.. Any Hx owners with a finely tuned Mpguino that would like to shed some light? I guess all of the settings info would be helpful as a starting point. Please and thanks
Old 05-25-2015, 01:47 AM   #2 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Sorry only running a vacuum gauge here. The mpguino wont be able to calibrate for lean burn but it will give you a good base to drive with.
There are only a few hx members still active but they are Very fun to daily drive as it becomes the gas mileage game
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
Old 05-25-2015, 02:10 AM   #3 (permalink)
Really? It was my understanding that this was the advantage of Mpguino over scanguage being that scanguage is a set AFR device..
I have contemplated installing a vacuum gauge and/or scanguage(mainly for TPS & Temp). Have you found that a vacuum gauge has allowed you to better maintain lean burn?
Old 05-25-2015, 02:40 AM   #4 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
I also assumed Mpguino could detect and give accurate display of lean burn.
Anyway, set this for your microsec/gal, should be dangerously close.
315451000
Those should be the first 9 digits. The rest will be 0's. As an example, I don't know how many digits there are total...
000315451000
The Following User Says Thank You to Baltothewolf For This Useful Post:
Cd (11-12-2023)
Old 05-25-2015, 03:06 AM   #5 (permalink)
Thank you Baltothewolf. Much appreciated. I'll at least be close for now. I am now on my 3rd try calibrating lol as I have inadvertently disconnected my battery while working on the car for the 3rd time before using up my tank. While it's a good practice, it is not so good when you then realize the device has reset.
Old 05-25-2015, 10:15 AM   #6 (permalink)
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
I use the Mpguino on my HX and it is dead on. Well it was my HX but it's my sons now. It's the only monitor that I know of that does work with lean burn.
Old 05-25-2015, 12:10 PM   #7 (permalink)
Great to hear iveyjh. Sounds like I'm in good company on here. Assuming that your Hx is 49 state emissions and is 96-00 is the value set for microsec/gal similar to the one stated by Baltothewolf? Also regarding the other settings on the device are they as follows?
VSS Pulses/Mile : 0000008208
Microsec/Gallon : 0315451000
Pulses/2 revs : 0000000001
Injector DelayuS : 0000000500
VSS Delay ms : 0000000002
InjType 0,1,2 : 0000000000
Much appreciated. Sorry for all of the questions but I truly want this device to be dead on lol
Old 05-25-2015, 02:42 PM   #8 (permalink)
iveyjh's Avatar
I didn't mess with any settings but VSS/Gallon & Microsec/Gallon and I don't remember what they were with stock setup. I have changed fuel pressure since then and it had to be re-calibrated. I'd go with the other guys starting point and do a calibration at the next few fill-ups.
Old 05-25-2015, 03:14 PM   #9 (permalink)
Oh ok, Good deal. Just checking (& double checking lol). You mention an AFC on your Hx. So is that to say you are running open loop all the time at a constant predetermined AFR? Better FE?
Old 05-25-2015, 03:42 PM   #10 (permalink)
Furry Furfag
No problem at all, glad to help. Just stop unplugging your 12v :P
