Go Back   EcoModder Forum > EcoModding > EcoModder Blog Discussion
Old 07-25-2008, 02:31 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
MPGuino stuff
Lemme know if I forgot anything superbly important: http://www.ecomodder.com/blog/2008/0...-for-under-50/
Old 07-28-2008, 08:43 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Just a couple things:
1. The cell phone charger thing is a flaky proposition at best, build the 7805 circuit:
Freeduino V1 v V2?
2. Also, it MUST be connected to battery power so it is powered when the key is off, or in run, or in start. I have a few lighter outlets and one is off in start, the other is off when the key is off. That's no good for an mpguino, you will lose your tank trip or worse.
3. it said 8204 for the asian vsspulses per mile, should be 8208.
Old 07-29-2008, 05:25 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Oh, it needs to be powered all the time? That might be what I'm missing...I'm guessing it doesn't eat enough power to make the battery notice, eh?
Old 07-29-2008, 06:17 PM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
it draws maybe 40 milliamps (last time anyone measured), not usually enough to worry about. The LCD will turn off by itself after 7 minutes of inactivity.
measurements on the currents
Old 07-29-2008, 06:21 PM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
Cool, thanks, didn't read enough the first time.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
mpguino TDI feasability dcb OpenGauge / MPGuino FE computer 28 05-08-2009 07:20 PM
Some suggestions and notes on the MPGuino SVOboy OpenGauge / MPGuino FE computer 4 08-01-2008 09:00 AM
